Check coolant additive
Old May 13, 2017 | 07:55 PM
kopy kat's Avatar
kopy kat
So at 39,000+ miles the "check coolant additive" message comes on....is this another "reminder" like the one I saw at 20,000 miles or does actually mean something?
Oh yah, I also need to look at the owners manual...but it's clear outside in the truck.
Thanks, Larry
Old May 13, 2017 | 08:33 PM
EO2SeaBee's Avatar
EO2SeaBee
It is just another reminder to test the coolant - like the one you have already seen.
Old May 13, 2017 | 08:57 PM
JohnD333's Avatar
JohnD333
Yes, just a reminder to check that the antifreeze level is at good strength, radiator is not leaking so level is right, and that there is no contamination needing a booster or flush/change. That said, read the manual if you tow a lot. The normal flush/drain interval is drastically reduced uf youbtiw a lot and manual specifically states if additive is otherwise indicated, flush and drain instead...
Thanks, Larry
bizzelj
Jul 29, 2015 09:26 PM
lwk362393
6.7L Power Stroke Diesel
May 7, 2014 06:21 AM
MandolinMan
Jan 17, 2014 10:50 PM
KC8QVO
Sep 10, 2013 11:23 PM
