300-6 Fuel Filter
Old Apr 16, 2017 | 05:32 PM
GreenMtnMan's Avatar
GreenMtnMan
300-6 Fuel Filter
After having the pickup sit all winter it will run for a second if I pour gas into the carburetor. I want to change the fuel filter, it looks like it unscrews, there's three notches on the end, perhaps for a special wrench? I also note the choke plate is shut tight. Plenty of gas in the tank. Maybe the float is stuck at the bottom of the carburetor.
Old Apr 17, 2017 | 09:37 AM
Brian_153624's Avatar
Brian_153624
I would first check to see if you are getting fuel past the fuel pump. I then check to see if you have gas to to pump. I have had a full tank that was plugged up with the paper gasket from fuel additives. I have also had to replace worn out fuel pumps. I would change the filter now anyway.
Old Apr 17, 2017 | 02:00 PM
1986F150six's Avatar
1986F150six
Depending on year, etc., some chokes are supposed to be shut tight and others, not. Why not take a screwdriver [large enough to not fall in] and prop the choke plate slightly open. Give it a try and see if it starts.
Old Apr 19, 2017 | 05:41 PM
GreenMtnMan
How does the cap to the gas filter come off? It looks like it's been on there since Hector was a pup!
Old Apr 19, 2017 | 06:09 PM
AbandonedBronco's Avatar
AbandonedBronco
Are you able to take and post up a picture of the filter? It sounds like it might be an older design.
Otherwise, I've had my engine not start once because of the choke. I had really torn a lot of things in the engine apart trying to figure out what was wrong before I realized the choke was simply closed all the way and not letting any air in.
Old Apr 20, 2017 | 01:33 AM
GreenMtnMan
I'll try to get a picture.The choke plate is fully shut at the moment. I really only have time to work on this on the weekend.
Old Apr 20, 2017 | 10:36 AM
1986F150six
That hose at the back of the valve cover [pointing straight up] needs to be connected to the air cleaner.
Old Apr 20, 2017 | 03:04 PM
GreenMtnMan
Thank you, please let me know if you spot anything else not right.
Old Apr 23, 2017 | 02:44 PM
GreenMtnMan
Success! I was able to get the metal filter cover off using a Lisle tool I bought for taking off hard to get to oil filters. Put the new filter in and she started right up. I noticed a small port on the right side of the carburetor and wondered what is supposed to be there.
Old Apr 24, 2017 | 08:58 AM
1986F150six
Usually, that port supplies filtered make-up air, through a reddish [silicone?] vacuum hose, which is connected to the metal tube connected to the bottom of the exhaust manifold [near the #5 cylinder]. On the top of the intake manifold at the same spot, is another metal tube, normally covered with a fabric [asbestos?] sleeve, for insulation, and is connected to the choke heater housing. This system supplies hot air to the choke so the bimetallic metal spring will adjust the choke plate as the engine warms up.
Maybe this link will help explain how the choke works: https://www.ford-trucks.com/forums/1...ent-101-a.html
BrownBadger
Aug 17, 2015 05:08 PM
Jessee1979
Oct 10, 2010 09:07 PM
wyazel1
Jul 2, 2008 05:54 PM
MO CUB
Feb 27, 2008 06:49 PM
Scavenger
Aug 18, 2002 10:12 PM
