2 Layers in inline fuel filter wtf?
Old Jun 29, 2008 | 03:33 PM
wyazel1's Avatar
wyazel1
My 78 has sat for about one month it has sat longer than that before without the gas going bad, but it wont stay running now and the fuel in the inline fuel filter is in 2 'layers'. The top layer is clear and the bottom layer is milky looking. Is this bad gas? I just replaced the filter today it will stay running if i keep feathering the gas but if i let go it idles down and dies. any ideas?
Old Jun 29, 2008 | 04:14 PM
wyazel1's Avatar
wyazel1
I disconnected the fuel line that goes from the pump to filter to carb, I unhooked it from the carb and cranked the engine and pumped some gas into a container it definitely has 2 distinct layers. Is there a way to pump the fuel out without cranking the starter?
Old Jun 29, 2008 | 05:02 PM
fmc400's Avatar
fmc400
MSEE
There was a thread about this not too long ago; the general consensus was to either crank the starter or siphon. There could be varnish in the carburetor that keeps it from running, too.
Old Jul 2, 2008 | 05:54 PM
Byteme's Avatar
Byteme
Gas doesn't usually go bad that quickly, sounds like you may have said somethhing wrong to the wrong person maybe. Might want to invest in a locking gas cap.
Anywho, autozone sells a universal electric fuel pump for about 20 dollars, you could just temporarily hook it to the line from the fuel tank, with a filter in front of it, and let it pump your tank dry. Alot easier than siphoning, ans safer.
My two cents.
yzhammer
Feb 3, 2017 04:21 PM
diesel_dan
Jul 27, 2016 03:53 PM
martinkik
Mar 14, 2016 04:58 PM
Bruker
Aug 6, 2008 12:10 PM
rickthefix
Jun 29, 2008 10:31 PM
