Torque Pro question
Old Apr 15, 2017 | 08:19 PM
David Fehir's Avatar
David Fehir
Torque Pro question
Hey guys I heard someone on this forum mention torque pro as a good and cheap way to get fault codes off your computer in your truck so I downloaded the app and got the Bluetooth plug in for my computer in my truck and hooked everything up the app works great showed me all my fault codes and that's how I found out I need to replace number 4 injecter but some gauges don't work with my truck my question is does any of you guys know how to get all gauges to work? Could it also be that some gauges just won't work with my truck for example one of the gauges I was trying to get to work was the fuel trim bank senser gauge and horse power gauge if anyone has any tips please help thanks in advance ps my truck is a 03 6.0
Old Apr 15, 2017 | 08:31 PM
bismic's Avatar
bismic
I don't think you have a fuel trim bank sensor.
Not sure about hp or load
Old Apr 15, 2017 | 08:37 PM
David Fehir
That would explain why those gauges won't work but I wonder why the horsepower gauge doesn't work?
Old Apr 15, 2017 | 11:14 PM
Yama4fitty's Avatar
Yama4fitty
A lot of the sensors listed do not work in TP for our vehicles.
The best way to determine if a sensor is "active" is to go into TP while connected to the vehicle and "add display" like you would normally to add any PID you wish to have showing. When you go into the add feature there will be a number of listed displays that are illuminated with a green background. Those are the active PID's the vehicle is actively seeing. So those are the PID's you can add for monitoring.
My TP at the moment will not allow me to monitor Baro and EBP for some reason, which is why I normally use FORScan.
There is also an additional downloadable app for TP that is called Torque Scan. Is is made by the developers of TP. It will list active PID's for your vehicle once you download the app and run it with TP on your vehicle. It attaches itself to TP and will be listed in the main menu of TP as Torque Scan.
Old Apr 16, 2017 | 08:07 AM
David Fehir
Thank you that was helpful
bigb56
13
May 31, 2017 11:34 AM
Money-Pit
Sep 9, 2016 12:06 PM
tjmike
39
Mar 27, 2016 03:46 PM
bookem15
Jul 4, 2015 01:04 AM
High76boy
May 19, 2014 01:26 PM
