Torque Pro app - installing and using
I'm going to put together some videos and instructions on how to get Torque Pro, how to add gauges, and how to use the app on your phone/tablet. I do not know everything about Torque Pro, so hopefully other people will add to this thread. I mainly use it to monitor several gauges at a time while on long trips. Currently, Torque Pro is only available for Android devices, and it will not work with Apple products.
You will need:
Torque Pro app - $ 4.95
Android phone or tablet - $ varies
OBD2 bluetooth adapter - $20-25
There are some OBD2 bluetooth adapters that work and some that don't. Maybe some people can list what has/hasn't worked for them.
I use the BAFX adapter bought at Amazon, pictured below. (Some people don't like the crazy blinking light show it puts out, never bothered me, but if it ever did, I'd put some electrical tape over the lights.)
Amazon link to it...
Below is a video on how to get Torque Pro on your Android device, and some general info about setting it up. EDIT: I apologize for the crappy video quality...you can count the hairs on my knuckles, but the tablet screen is blurry
<IFRAME height=360 src="//www.youtube.com/embed/OkKFdPvVmTE?rel=0" frameBorder=0 width=640 allowfullscreen=""></IFRAME>
Below is a video on adding gauges to make your custom display. I also show how to create the "delta" gauge, to show the difference between your coolant and oil temps. (bear with me on the video, I was doing this on a tablet that I no longer use, and I had issues trying to remember wtf to do.) EDIT: once again, I apologize for the crappy video quality
<IFRAME height=315 src="//www.youtube.com/embed/6IwKT-QhL6A" frameBorder=0 width=560 allowfullscreen=""></IFRAME>
Once you have all the gauges you want set up in Torque Pro, you may want to create audiable alarms for some, or all of your gauges. This is a very nice feature....such as if you're in heavy traffic or any reason you don't want to take your eye off the road to glance at the gauges. You can set a high or low alarm. (you can't have both a high and low alarm on the same gauge) An example of a low alarm is if you want to be alarmed if your FICM main power dropped to 46 volts or less .....a high alarm would be good on ect/eot deltas, or maybe boost over 28 psi, etc.
FUTURE.... Video below shows how to set up audible alarms
The first one I use to monitor the most common sensors while driving, the second one I call my diagnostics screen to view things I wouldn't normally need to watch while driving...but may need to help diagnose an issue.
On main Torque Pro page, click on your Android menu button (on "most" android devices, it is the button left of your home button)
Click settings
Click "manage extra pids / sensors"
Click your Android menu button again
Click "add custom pid"
A caution message "may" come up..if it does, click OK
The OBD2 PID editor will be shown, fill in each item as shown in picture below
When done, there should be a save/OK or similar button at bottom....click it to save the delta gauge.
If you use Torque Pro on several different type of vehicles with its own custom PID or dashboard. You can set so that each vehicle profile to have it own custom PID and dashboard display.
Select or Create a new vehicle profile
Scroll down until you see "Use separate dashboard layout" and check mark the box next to it.
Save profile
You will need to create a dashboard for each profile if you choose this method but it will help prevent error or seeing a dead gauge if you use it in a vehicle that does not support such PID or custom PID from a different vehicle.
Bill
How do you get the ICP? Is that the same as HPOP renamed to ICP?
Also where can I find ICP V?
Thank you
Bill
Bluetooth Adapters - Torque OBD2 Wiki
By all means, do NOT get .
ICP volts may have been another manually entered one. Here's the editor page. ( had to give you upper and lower part of page...cant get a screen shot of whole thing at once.)
