Electrical
Old Apr 14, 2017 | 12:25 AM
62FE4x4's Avatar
62FE4x4
Electrical
I have a 96 F350 that is giving me some electrical trouble. While driving down the road a few accessories go out simultaneously, and then a few minutes later or a few hours later they start working again.... which might last a few minutes or a few hours. The radio, windows, and a/c all stop working at the same time. I am leaning towards it being an ignition switch.... any ideas? I have had several of this bodystyle, but nothing like this gas ever happened. If it were a 2002 model I would assume it's a gem module, but that didn't exist yet in 1996. All suggestions welcome....
Old Apr 14, 2017 | 07:27 AM
Tim Hodgson's Avatar
Tim Hodgson
Maybe post in this subforum?
https://www.ford-trucks.com/forums/forum62/
Old Apr 14, 2017 | 08:16 AM
subford's Avatar
subford
Yes it would be the Ignition switch that is bad or the wiring between the Ignition switch and the dash fuse panel.
Old Apr 14, 2017 | 10:20 AM
62FE4x4's Avatar
62FE4x4
I agree....
Sometimes when I move the key and tumbler just a bit the accessories will kick back on. I thought it was probably worn to have all that play in it
Old Apr 14, 2017 | 10:42 AM
subford's Avatar
subford
Why I say the Ignition Switch:
AS you can see in diagram 13-22 below the Radio is powered by fuse 11, the windows by CB 14 and the AC by fuse 6. These all have a common power source.
Looking at diagram 13-3 below the common source for this power is the Ignition Switch.
Note that fuse 17 in the engine fuse/relay box powers this output from the Ignition switch but fuse 17 also powers the Ignition system and you said nothing about the truck cutting out.
Old Apr 14, 2017 | 11:53 AM
62FE4x4's Avatar
62FE4x4
Yep....
No the truck never cuts out when running. It is incredibly hard to start if it has set more than a couple days, but I think that is a different issue. Would you suggest I pick up a key and tumbler too? Just picked up the electrical switch
Old Apr 14, 2017 | 03:27 PM
subford's Avatar
subford
I would start with just the switch.
Old Apr 14, 2017 | 03:43 PM
62FE4x4's Avatar
62FE4x4
Just picked up the switch. Would you change the key & tumbler also, or is that irrelevant to this particular issue?
Old Apr 14, 2017 | 08:44 PM
subford's Avatar
subford
It is irrelevant to this particular issue.
Old Apr 14, 2017 | 09:02 PM
62FE4x4's Avatar
62FE4x4
Success
Replaced the new Ignition switch at the TA Truck Stop in Albuquerque. All went well...Just like a new truck again. Thanks for all the input
gaffmedic
Apr 5, 2017 02:15 PM
ChrisMelton78
Jun 20, 2014 03:01 PM
harbor97
Nov 10, 2013 05:19 PM
teppler
Sep 16, 2011 09:53 PM
mikefraz01
1978 - 1996 Big Bronco
Mar 19, 2005 03:40 PM
