1978 - 1996 Big Bronco
dead ignition
Old Mar 19, 2005 | 03:33 PM
mikefraz01's Avatar
mikefraz01
dead ignition
gotta ask again... i have an 88 bronco, the battery is fully charged, however the ignition swicth gets no power.
if i run a jump wire in the fuse box from the "always powered" slot, to the "ignition on" slot... then the ignition switch gets power, and the key works, but doesnt start the car, you still have to jump the solenoid, i have checked all the fusable links near the selonoid and all are fine, all fuses are fine... what in the hell can this be? cant be the selonoid, because if it were, than the ignition switch would work fine, cant be the ignition switch because i have replaced it,
are there any other fusible links im missing?
Old Mar 19, 2005 | 03:40 PM
JBronco's Avatar
JBronco
Check this thread. He is having a similar problem.
https://www.ford-trucks.com/forums/s...d.php?t=355826
