Engine missing/bucking at WOT
Old Apr 9, 2017 | 12:29 PM
fyrehose's Avatar
fyrehose
I have been having a problem for a while now where my truck will miss/buck at WOT. This only happens at higher RPM's. From a standing start 0-60 it is fine. However when I downshift full throttle from about 50 MPH it initially goes, but then it will miss/buck consistently until I back off the throttle.
I have so far replaced the CPS, re torqued injectors, checked valve cover harnesses and fuel pressure stays in between 64-58 full throttle. No codes show up.
My truck runs great except as I described above. I would think an injector or two are bad, but the truck runs and idles great. My initial guess was that it was a fuel pressure issue, but fuel pressure holds strong. Could it be air in the fuel?
Old Apr 9, 2017 | 02:06 PM
Hussler's Avatar
Hussler
I can guess. With bigger injectors and tunes might be running out of high pressure oil. Do you have the stock HPOP? Can you monitor ICP and IPR%, that would tell the story? Any CEL light when this is happening?
Old Apr 9, 2017 | 04:48 PM
fyrehose's Avatar
fyrehose
I have monitored icp/duty cycle and ipr on AE and it is holding good (3300). I don't know the characteristics of a bad injector, but I don't know what else it could be.
Jimmy Cash
Jul 12, 2016 07:42 PM
tr0y
Dec 13, 2015 09:45 PM
jchosler
Dec 7, 2015 11:19 AM
TruckoffFord
May 9, 2015 06:12 AM
97biostroke
Feb 12, 2009 03:30 PM
