engine not running smooth
Old May 7, 2015 | 04:19 PM
TruckoffFord's Avatar
TruckoffFord
2003 F350 6.0 with 290k+
It has a skip in the engine at idle and running. At times when running down the road skip seems to get worse.
Changed both fuel filters, didn't help.
truck start up is normal, no leaks, and flashing no codes.
Any suggestions?
Thanks
Old May 7, 2015 | 04:34 PM
mustang_309's Avatar
mustang_309
Any suggestions?
Thanks
What are you reading codes with? You can have pending codes without a check engine light.
Old May 8, 2015 | 09:33 PM
TruckoffFord
Thanks Mustang 309 for the tip. You were right, there was a problem giving no code: #3 injector.
Will have the all 4 on right side replaced.
Old May 9, 2015 | 06:12 AM
mustang_309
Also have the check the dynamic fuel pressure ( fuel pressure at wide open throttle under load condition ) it needs to be greater than 45 PSI or injector damage can occur, the further below 45 PSI the greater the chance of having injector damage. Low fuel pressure is the leading cause of injector damage. It would also be a good time to do the fuel pressure regulator blue spring upgrade.
ATV PRO #11
Mar 15, 2021 08:15 AM
fyrehose
Apr 9, 2017 04:48 PM
Zeropowerstroke99
Jan 24, 2017 06:33 PM
ampslw
15
May 31, 2012 12:51 PM
voluntier
Sep 25, 2011 11:21 AM
