EBPV
Old Apr 8, 2017 | 08:46 PM
IH Addict5088's Avatar
IH Addict5088
EBPV
Does anyone know where I can get an ebpv other than being directly from ford?
Old Apr 8, 2017 | 10:57 PM
Chevota_72's Avatar
Chevota_72
Dieselorings.com or Riffraff.com
Old Apr 9, 2017 | 12:56 AM
retiredsparky's Avatar
retiredsparky
If you understand how to bend tubing, you can buy brake tubing of the same outside diameter to replace the tubing, if it is rotted out or so clogged that it cannot be cleaned.
Old Apr 9, 2017 | 08:28 AM
Walleye Hunter's Avatar
Walleye Hunter
Let's clarify what is being looked for here. He has asked for an EBPV, not the tubing or a sensor. I never heard anyone ask about replacing the EBPV yet.
Old Apr 9, 2017 | 08:36 AM
IH Addict5088
I'm looking for the actuator for it that goes into the pedestal. Might just delete it if I can't find it. Probably cheaper to do that anyway.
Old Apr 9, 2017 | 08:42 AM
Walleye Hunter
OK, you're looking for the EBPV solenoid. I'd recommend Ford or Riffraff or DieselOrings if they have it. If you're going to delete it you should also do it properly with a delete pedestal, sooner or later the thing will leak oil.
Old Apr 9, 2017 | 09:02 AM
IH Addict5088
http://ktperformance.net/i-23443268-dfuser-exhaust-backpressure-valve-terminator-ford-1999-03-7-3l-power-stroke.html
Has anyone heard of this?
Old Apr 9, 2017 | 09:15 AM
Walleye Hunter
Here is same thing only cheaper. Reports are that they do their job.
EBP Pedestal Actuator Isolator Pigtail for Ford 7.3L 99-03
Old Apr 9, 2017 | 10:19 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
You can use a 470 ohm 1/2 Watt resistor like some of us have and achieve the same results. They are about $1 and serve the same purpose.
I did this last year when I deleted the EBPV.
Old Apr 9, 2017 | 10:29 AM
IH Addict5088
When I delete the ebpv do I need to get the non ebpv pedestal?
Old Apr 9, 2017 | 10:34 AM
Walleye Hunter
I didn't. My situation was a little different, the pedestal I have is brand new so I wasn't worried about it leaking for a while and I already spent my wad on other parts. I left the solenoid connected so it doesn't throw the code.
locknload223
31
Mar 11, 2011 02:49 PM
swaybar
Jan 25, 2009 05:35 PM
Farmboypowerstroke
53
Jul 20, 2008 06:52 PM
ha305
Mar 10, 2008 05:43 PM
ForemanES
Oct 28, 2005 06:45 PM
