I was
Old Jul 18, 2008 | 02:45 PM
Farmboypowerstroke's Avatar
Farmboypowerstroke
Old Jul 18, 2008 | 03:03 PM
mueckster's Avatar
mueckster
EBVP sensor is used by PCM for fueling. The tube needs to be replaced for the sensor to read properly.
Old Jul 18, 2008 | 03:12 PM
Farmboypowerstroke
i wonder if my sensor would be ok? I dropped it on the cement would that hurt it much?
Old Jul 18, 2008 | 03:53 PM
mueckster's Avatar
mueckster
It's not that delicate. Just flush it out with some brake cleaner and blow out the opening on the bottom. If it's stopped up too bad, it may need to be replaced. I just recleaned the soot from mine recently. After cleaning, it looked brand new inside.
Old Jul 18, 2008 | 03:54 PM
superduty4x4's Avatar
superduty4x4
Nah you probably didn't hurt it. BTW, welcome to FTE! Be cautious of this place, we'll soon have you spending rediculous amounts of money on your truck
Old Jul 18, 2008 | 04:04 PM
Farmboypowerstroke
Thanks for the welcome, I've spend alot of money already.
Old Jul 18, 2008 | 04:24 PM
mueckster's Avatar
mueckster
PMS is a powerful thing. You just can't help yourself but give into the temptation to mod.
Old Jul 18, 2008 | 04:36 PM
John311t's Avatar
John311t
You can run it without the sensor or tube and you might see a small difference in performance. It wont hurt the truck one bit to run without it. It is used in the fueling tables, but without it, the difference is small. So run it with the big hole in it until you get the new tube installed. Your sensor should be fine.
Old Jul 18, 2008 | 05:45 PM
ron's power stroke's Avatar
ron's power stroke
whenever cleaning a sensor..always make sure the electrical end is dry before you plug it in...its always' wise after cleaning the sensor to clean the electrical end with electrical cleaner in a spray can..its made for sensors..it is also fast drying..then dab some electrical grease in the plug before you plug it in..the cleaner will both chase out the brake clean or water and it cleans the plug end..the grease will keep a good connection as well as keep moisture out...both can be found at most any parts store...i do this on every plug i take apart on my truck..even if its under the dash..my gauges even have a dab of grease on them...windshields tends to collect moisture and the warm gauges are right next to it...
Old Jul 18, 2008 | 05:53 PM
big poppa's Avatar
big poppa
LOL, if i put a install date on all my mods, your wallet would be screaming. Welcome to FTE.
Old Jul 18, 2008 | 05:55 PM
superduty4x4
My wallet is already screaming everyday. I would like to make it scream more, but don't want to listen to the wife's screaming as well.
Old Jul 18, 2008 | 06:28 PM
John311t's Avatar
John311t
My wallet used to be empty, I am just now re-couping from damages. LOL, and the motor is still running stock sticks and air.
Old Jul 18, 2008 | 06:36 PM
big poppa's Avatar
big poppa
Man, this is an addiction!!!!! But i can handle it
Old Jul 18, 2008 | 06:44 PM
Farmboypowerstroke
Hey John311t I see you have big fuel lines. Could you explain this, and how you did it? What fuel lines are you talking about? Does it increase hp?
Old Jul 18, 2008 | 06:46 PM
Farmboypowerstroke
O and one other thing, i know i should post this here but, Why can't I private message anyone?
