Fuel Pump?
Old Apr 13, 2017 | 01:46 PM
  #31
Brian1971f100's Avatar
Brian1971f100
Originally Posted by 72CC428
Hey Brian, why can't you just replace the pick up line? Is it welded to the tank inside?
Yes it is. Maybe not welded but permanently attached.
Old Apr 14, 2017 | 02:54 PM
  #32
Tedster9's Avatar
Tedster9
I'm sure a handy sort could fabricate some kind of replacement, but it's true, they aren't designed for removal and replacement as a separate component.
Old Apr 19, 2017 | 01:34 PM
  #33
TeachNlive4ever's Avatar
TeachNlive4ever
Jeffafa, remember when the Green Hornet was doing the same thing? I replaced everything, even tried an electric fuel pump. Ended up buying a new gas tank, problem solved.
Old Apr 19, 2017 | 01:57 PM
  #34
JEFFFAFA's Avatar
JEFFFAFA
The Green Hornet and Kato. Did you know that Kato was played by Bruce Lee?
Old Apr 19, 2017 | 02:36 PM
  #35
wooddyusa's Avatar
wooddyusa
can I find a new aftermarket or replacement tank for behind the seat?
Old Apr 19, 2017 | 02:40 PM
  #36
TeachNlive4ever
I bought mine mine from LMC. You'll have to torque down the center nut where the lead to the sending unit goes. It'll leak.
Old Apr 19, 2017 | 02:42 PM
  #37
wooddyusa's Avatar
wooddyusa
Thanks! Any idea how many gallons the aux tank Is?
Old Apr 19, 2017 | 02:44 PM
  #38
TeachNlive4ever
Mine are 20 gallons. The new LMC tank is 18. I had to monkey with the sending unit as my original was 19.5 gallons, I believe.
Old Apr 19, 2017 | 02:45 PM
  #39
JEFFFAFA's Avatar
JEFFFAFA
DC has them at www.dennis-carpenter.com Their part number D0TZ9002A.
Old Apr 19, 2017 | 03:59 PM
  #40
wooddyusa's Avatar
wooddyusa
thanks! I may hold off on a new tank until I confirm this 360 is in decent shape. Still gotta get to the compression check. Hopefully tonight. What the rule for compression? None should be lower than 15% of the best one?
Old Apr 19, 2017 | 04:51 PM
  #41
JEFFFAFA's Avatar
JEFFFAFA
Correct. That is what I was taught in High School vocational Auto Mechanics circa 1973 1/2 TO 1975.
Old Apr 20, 2017 | 10:02 AM
  #42
wooddyusa's Avatar
wooddyusa
Ok the results are in. All cylinders came back between 110 - 117. Except Cylinder #4. 85-90.
Old Apr 20, 2017 | 04:26 PM
  #43
JEFFFAFA's Avatar
JEFFFAFA
Also Im noticing a ton of vacuum from the breather on the valve cover. Its not hooked up to the air cleaner. I have to plug it for the truck to run. Im gonna do a compression check later. Seems like it is missing on one cylinder.
Is it intake manifold vacuum air going in the valve cover or "blow by" air coming out?
Did you do a "wet" compression test also? Squirt about 4 heavy squirts of oil in the cylinders individually with an oil can then test each cylinder again. This oil will temporarily seal the rings if they are worn or broken.
Old Apr 20, 2017 | 04:37 PM
  #44
wooddyusa's Avatar
wooddyusa
it's vacuum. I plugged it and the truck idles good. Unplugged and it barley runs.
I did put a couple tsp of oil in the cylinder and it can up to 90. 83 was dry.
Old Apr 20, 2017 | 04:54 PM
  #45
JEFFFAFA's Avatar
JEFFFAFA
Hmmm. Intake vacuum in the crankcase. Sounds like a cracked intake. Which intake manifold is this? Original 2V intake? Swapped on Ford 4V? Swapped on aftermarket 4V? Do the gasket surfaces of it look like it was installed recently?
