redline
Old Sep 3, 2003 | 09:54 PM
fordeverpower's Avatar
fordeverpower
redline
the tach is a super pro tach. The engine more or less pulls about 2/3 of the rpms at 55mph with the 4.10s.
Old Sep 3, 2003 | 10:40 PM
Randyb12's Avatar
Randyb12
redline
Exchange the Tach. It sounds like you got a defective one. After you install the new one check the readings again. let us know what happens.
Old Sep 3, 2003 | 11:13 PM
dinosaurfan's Avatar
dinosaurfan
redline
I don't know if your tach is working correctly, or wired up correctly, or not. But if you really are only getting 3800 rpms, something is wrong. What valvesprings were installed on that '2 steps larger' cam ? If the valve springs are weak, or if they are the stockers on a big cam, that would cause problems. DF
Old Sep 4, 2003 | 05:32 AM
pat67shorty's Avatar
pat67shorty
redline
The problem is your tach, I'm sure of it. I had one of those cheap *** super pro tachs. It always read about 500-600 rpm fast, untill it one day would not read over 2,600 no matter how high I revved the engine. Get the slightly more expensive Sun Pro tach, it is better. Or if you'r not on a budget, Auto guage/ Auto Meter tachs are nice.
Old Sep 4, 2003 | 03:25 PM
fordeverpower
redline
I hooked the green tach wire to the green wire into the coil. Which is the negitve wire, I believe.
Old Sep 4, 2003 | 05:59 PM
FE427TP's Avatar
FE427TP
redline
did your coil get hooked up backwards?
Old Sep 4, 2003 | 06:34 PM
fordeverpower
redline
how could it get hooked up backwards?
Old Sep 5, 2003 | 08:48 PM
luvfordtrucks's Avatar
luvfordtrucks
redline
an igniton coil can be hooked up back ward and the engine will still run, but not like its supposed to.
you want the voltage or hot wire going to the positive side of the coil, some where on the coil top it should have a plus sighn for positive or a sighn that says bat for battery, and the negative side goes to the points or what ever trigger switch your using ( pertronix etc).
most tachometers have 4 wires, red, black, green, and white.
the red wire goes to a 12 volt source thats live when your key is switched on, the black wire goes to ground, the white wire is for the light for the tack ( you can hook this up any old time it doesnt have to be hooked up for the tach to work ) and the green wire goes to the negative side of the coil.
and like mentioned above, you may want to get a new tach if you suspect yours is flaking out or if its possible its been wired wrong.
61steven
15
Aug 16, 2014 06:29 PM
ASNWRULZ
24
Apr 18, 2010 05:33 PM
matthew35
Oct 17, 2006 12:07 PM
RotGrubestier44
27
Dec 10, 2005 09:14 PM
Stingray42
Dec 21, 2003 11:03 PM
