4-bolt Main conversion?
Old Sep 1, 2003 | 09:45 PM
Randyb12's Avatar
Randyb12
Has anyone here done the 4-bolt conversion? If so where can I get the kit? Was it difficult? How much did it cost?
Old Sep 1, 2003 | 11:15 PM
FE427TP's Avatar
FE427TP
you dont really need it until past 500 hp or continuous use above 5000RPM but program engineering has the kit and it needs machine shop work it's not something a regular joe can do
Old Sep 2, 2003 | 10:20 AM
Randyb12's Avatar
Randyb12
I did a google search. But was not able to find Program engineering. How do I contact them.
I was going to use a blower but decided to go with nos. I will be producing somewhere around 850hp on the bottle. I don't want to be walking back down the track picking up engine parts!
Old Sep 2, 2003 | 02:05 PM
BB's Avatar
BB
Try these guys:
http://www.pro-gram.com/
Old Sep 2, 2003 | 09:34 PM
Randyb12's Avatar
Randyb12
Thanks!
Old Sep 3, 2003 | 06:37 PM
hotrodfeguy's Avatar
hotrodfeguy
I would also say a 4 bolt conversion would be over kill.I woud think the money could be better spen upgrading from that 6-71 supercharger to a 8-71 Just my two cents
Old Sep 3, 2003 | 08:28 PM
Randyb12's Avatar
Randyb12
I dropped the blower idea and decided to go with NOS instead. The blower was just too much $$. With all the engine mods I need to do for a blower: Forged pistons, rods and crank. I still need another 3000.00 for a blower setup. A two stage 425HP NOS setup runs 625.00. Even with the 4-bolt conversion I will save 2000.00.
Old Sep 3, 2003 | 10:39 PM
FE427TP's Avatar
FE427TP
I've never heard of a FE lasting extended periods of time with a 250 shot of Nitrous, let alone over 400 you'd better have a shelby block if you want it to last...
Old Sep 3, 2003 | 11:21 PM
dinosaurfan's Avatar
dinosaurfan
Randy, start saving your pennies. You'll need an aftermarket block to repeatedly stand up to 800hp punishment. Think Genisis, Arias, Shelby or, if you can find one, a Gould. The factory blocks are in trouble at a constant 600-650, with the crossbolts, maybe 750 is okay. Have you looked at Shoe's Capsaddles ? Might help. Anyway, for that heavy of an N2O load, you still need the better rods and the forgedpistons and forged crank. Speed costs money, how fast do you want to go ? DF
Old Sep 4, 2003 | 10:09 AM
Randyb12's Avatar
Randyb12
The TRW forged pistons came in yesterday. I am looking at some Eagle ESP 3DP Rods. Still looking for a good forged steel crank.
I really can't go over 600HP with all the forged pieces and 4-bolt mains. I am useing? Damn that is a major disappointment! I thought FE's were stronp blocks. guess not.
Old Sep 4, 2003 | 06:02 PM
FE427TP's Avatar
FE427TP
nitrous is not gentle, you'd be better off with boost and better pistons are TRW's even supposed to have that much N2O?
Old Sep 4, 2003 | 09:43 PM
hotrodfeguy
All I have to say is,BLAH
You don't need steel rods,or a steel crank remember the early 427's Ford ran cast cranks for some time in NHRA and Nascar.Just make sure its all balanced out and keep things spinning under 6000 RPM.As with almost any big block RPM's are not your friends.You can run cast pistons as long as you keep the Boost lower than 5psi or the NOS under 150HP after that you tend to run a chance of breaking rings, ring lands and the like.Its not like you would kick a rod under 6000 RPM. Or even destroy the block just upgrade to aftermarket rod bolts and main studs.Thats stuff that should be done to any hopped up engine.I know there is a blower guy in Chicago,IL that said he would rebuild my 6-71 for $650 with a warranty.He would also make the drive kit for about $800. And I found a guy that would sell me the Blue thunder intake for $625 new witch has to be close to cost.
Old Sep 5, 2003 | 02:53 PM
Randyb12's Avatar
Randyb12
Hotrod the guy Go here : http://www.flatlanderracing.com/edel...ds_bbford.html
They have a BT Blower intake for 469.00.
Old Sep 5, 2003 | 09:36 PM
Randyb12's Avatar
Randyb12
I heard that you can use a little Hardblock block filler to reinforce the block and still not over heat. they sele a short fill kit for street use. What do you guys think?
Robert Moore
Jul 2, 2015 08:11 AM
RedSinglecab4X4
May 30, 2015 03:29 PM
grosario
Nov 25, 2010 12:24 PM
countryboy4_1qt
Jan 31, 2007 04:35 PM
custom_67
Jun 15, 2004 09:28 PM
