Redline RPM
Old Oct 10, 2006 | 07:19 PM
matthew35's Avatar
matthew35
Redline RPM
I recently acquired a 1985 F250 diesel with the 6.9 Navistar. It is a T19 no OD equipped model. Unfortunately it has not tach. I calculated out a rpm at speed graph for every gear, but, I have no idea what the redline rpm's are. I know peak torque is at 1400 rpm, peak hp at 3300.
Does anyone know the redline rpm's?
Thanks
Old Oct 10, 2006 | 07:27 PM
dieself250's Avatar
dieself250
i recall seeing 3400-3800 rpms depending on engine load
Old Oct 10, 2006 | 07:33 PM
AndysFords's Avatar
AndysFords
I've never seen more than 3750
Old Oct 10, 2006 | 08:27 PM
Agemenon's Avatar
Agemenon
On the tach on my truck, the redline starts at about 3300. You probably should buy a tac and I woudlnt go past 3300 anyways....just a bad idea.
Old Oct 11, 2006 | 10:29 AM
Hamberger's Avatar
Hamberger
My tach has a yellow line and then a redline.
Yellow line starts at 3,300 rpm, redline starts at around 3,800 rpm.
My IP on the 93' turbo physically cuts out around 3,500 rpm when lightly loaded. (sudden loss of power) It probably would keep going further up to 3,800 under load.
Have never redlined my 91' N/A so I am not sure what it would do. Usually the the E4OD shifts up when you try to exceed 3,300 rpm.
Seb......
Old Oct 11, 2006 | 12:33 PM
Agemenon's Avatar
Agemenon
Ya I got the same setup as you seb.
Old Oct 11, 2006 | 11:01 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Most IP's are generally set up for 3500 to 3600 RPM at WOT and no load.
Some will not go that fast, others go faster.
Old Oct 12, 2006 | 12:28 PM
Agemenon's Avatar
Agemenon
Whats the maximum amount of time that you can stay in the yellow/red line before it starts to damage your engine, and does it matter if you're pulling something or not? Will the damage be more severe if you're pulling something?
Old Oct 12, 2006 | 01:11 PM
Hamberger's Avatar
Hamberger
You will know you have overdone it when:
  • Your windshield starts to turn green with Antifreeze.
  • Push Rods and Headbolt start to put dimples in your hood as they pop up against the hood.
  • The guy driving behind you starts turning on his headlights because his day suddenly went to night.
  • You are experiencing a sudden loss of power.
  • You suddenly realize that redline means don't run beyond that or bad things might happen to your truck.
Best of luck....
Seb.....
Old Oct 12, 2006 | 02:32 PM
Agemenon's Avatar
Agemenon
Ok...I know that part, I just want to know like...how many seconds can you stay in there before damage starts to occure. Like when you hard steer left or right, you're only supposed to do it no longer than 5 seconds or it will damage the pump or something like that.
Old Oct 12, 2006 | 10:11 PM
Dave Sponaugle
The engine is governed out at an RPM the engine can stand to run at for days at a time. driving around at 3300 RPM will be much harder on your wallet when you get to the fuel pumps than it will be on the engine.
The only way to overspeed the engine is dropping down a hill and letting the engine overspeed or downshifting at a speed to high for the next gear down.
I can run 48 MPH in third gear with my 4 speed at 3300 RPM.
If I tried to downshift from 4th to 3rd at 65 MPH the RPM would shoot up to 4400 RPM.
That would not be good for the engine or the wallet.
Old Oct 13, 2006 | 12:14 AM
TRIPLETS's Avatar
TRIPLETS
Wink
[QUOTE=Hamberger]You will know you have overdone it when:
Best of luck...
that was dam funny reading this reminded me of u might be a red neck if.........
Old Oct 17, 2006 | 12:07 PM
Agemenon's Avatar
Agemenon
lol...good point, I'll keep that in mind.
topscrt
Modular V10 (6.8l)
Sep 8, 2013 02:03 PM
true4.2
2004 - 2008 F150
Sep 17, 2010 05:49 PM
fordtrck302
May 4, 2005 10:06 AM
explorer72
Oct 16, 2004 08:32 PM
daywalker
Feb 9, 2001 11:55 PM
