6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Torque shift problems please help
Old Apr 4, 2017 | 09:32 PM
79sparky's Avatar
79sparky
Alright so problem started with code po0766 for solenoid d performance/stuck off. Wouldt shift to 5th. Doesn't even attempt to shift. Sometimes it will act like its confused shifting from 3rd to 4th. Reverse ours slow to engage but engages strong, with that said its a lottle shaky sometimes after it's warmed up. So i got the mts stage 2 direct clitch solenoid, epc solemoid, and dummy sensor plug. Still no change. Even threw the code again. I used dex/mercon lv fluid, which i was told was a suitable replacement for the apparently nonexistent mercon sp fluid. Not gonna lie didn't replace the valve body gasket bestie i wad told you could pull down the wiring harness plug though found out that's not the case because of the oring. Bad clutch pack or something else going on, thanks.
Old Apr 5, 2017 | 03:37 PM
speakerfritz's Avatar
speakerfritz
I think there is a tranny section on the forum that may have some tranny deep divers who might be able to help. the one time I thought I had a tranny problem on a 5r110 , I checked into what I could do myself and the complexity and tool set needed made buy a reman more attractive . but it turned out my 5r110 problem was not a tranny problem and I did not have to cross that bridge.
Old Apr 5, 2017 | 03:45 PM
79sparky's Avatar
79sparky
I'll have to look for it. Im pretty sure the center section is totally toast though
Old Jul 30, 2017 | 09:01 PM
6.ohhprobs's Avatar
6.ohhprobs
Has anybody figured the problem out i am having the same problem and cant seem to get anywhere
Old Jul 30, 2017 | 09:16 PM
79sparky's Avatar
79sparky
What that problem ended up being was the direct clutch assembly being toasted. More than likely due to the original bearing, guess you could say defective, in the direct drive drum and center support that cause the direct drum to run slightly askew and cause excessive wear on said frictions. Guessing how some shift out of 3rd gear. The transmission housing flexes and the and can distort the center support new center supports and direct drums come with the updated bearings and supposedly the new center supports are stronger.
Old Jul 30, 2017 | 09:22 PM
79sparky's Avatar
79sparky
That's what my direct drive frictions looked like. As you can see there is no friction material left and it is no longer flat as it should be. The steels were blue and black instead of shinny.
Old Jul 30, 2017 | 09:25 PM
79sparky's Avatar
79sparky
Before you go with it being rebuilt if make sure it's not the Solenoid it self they are known to fail. The Solenoid is sspc-D direct drive Solenoid.
Vettedrmr
18
Sep 30, 2023 11:00 PM
ridinginstyle
45
Sep 21, 2015 03:09 AM
RomerB2
Bronco II
27
Aug 5, 2010 03:28 PM
400m
1983 - 2012 Ranger & B-Series
Apr 16, 2009 09:49 AM
walt227
May 9, 2007 03:37 PM
