Sponsored by: Auxito
Transmission...rough shift, not the cable
Old Apr 4, 2017 | 04:59 PM
Jrambellows's Avatar
Jrambellows
I have a 1998 Ford F-150 V8 Triton engine 5.4. I have replaced the shift cable with no issues. However it is still shifting rough. I've also tried tightening the two bolts on the steering column and that did not help as well. It's almost like you have to fight to get it into gear but on the road it shifts from gear to gear perfectly. Anybody have any suggestions?. It's an automatic transmission I have no slippage and everything else appears to run perfectly.
Old Apr 4, 2017 | 05:54 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It is probably a corroded Transmission Range Sensor (TRS.) That's the sensor on the driver's side of the trans where the shift cable attaches. If they get corroded inside they get really hard to move.
Old Apr 4, 2017 | 06:37 PM
kd4gij's Avatar
kd4gij
Is the shift lever sloppy?
Old Apr 5, 2017 | 12:12 PM
Bluegrass 7's Avatar
Bluegrass 7
Disconnect from the transmission end.
Is it still hard to move the shifter?
Disconnect from the lower steering column.
Is it still hard to move?
This has to tell you what part of the control the issue is at.
Good luck.
GIO23
Nov 3, 2010 11:48 PM
buymore
1997 - 2003 F150
Oct 23, 2006 03:59 PM
dadibones
Dec 18, 2005 07:46 PM
johare
1983 - 2012 Ranger & B-Series
Jun 7, 2005 01:32 PM
busbunch2002
Aerostar
Apr 6, 2005 08:34 PM
