hard to shift into gear
Old Nov 3, 2010 | 06:56 PM
GIO23's Avatar
GIO23
Hi, I have a 2000 Navigator that his hard to shift into gear, i just took the column apart and changed all the bushings and rods connected to the shift lever with no luck(mechanic friend said they all go bad, appartly he was wrong), how can i tell if the the shift cable to the trans is bad, tommorow i will check the linkages at the trans and lube them up if possible. any sugestions thanks giovanni
Old Nov 3, 2010 | 07:50 PM
alloro's Avatar
alloro
You could disconnect the shift cable and see if the column moves freely or not.
Old Nov 3, 2010 | 09:35 PM
GIO23's Avatar
GIO23
moves nice and easy with out the cable connected.
Old Nov 3, 2010 | 11:48 PM
alloro's Avatar
alloro
Now you know the column is good and the shift cable needs to be oiled or replaced.
67fordok
2009 - 2014 F150
Jul 20, 2014 03:56 PM
Ford Guy 72
1978 - 1996 Big Bronco
Feb 17, 2014 10:53 PM
scrobbie
Jan 18, 2014 06:12 PM
libnsvt
Feb 28, 2013 09:32 AM
walleye iowa
1983 - 2012 Ranger & B-Series
Dec 25, 2011 11:39 AM
