Last shot
Old Apr 6, 2017 | 06:42 AM
  #46
navistarnut's Avatar
navistarnut
Can you hear it change pitch after you start it up in the morning?
Should be doing that
Old Apr 6, 2017 | 10:40 AM
  #47
Knucks's Avatar
Knucks
Added map sensor and maf. This is at idle. Anything bad?
Old Apr 6, 2017 | 10:53 AM
  #48
BLADE35's Avatar
BLADE35
map is bad
map ebp baro should read same @KOEO
Old Apr 6, 2017 | 11:08 AM
  #49
FiznUKa's Avatar
FiznUKa
This^^. Show those readings at KOEO not at idle
Old Apr 6, 2017 | 11:41 AM
  #50
Knucks's Avatar
Knucks
Just went for a real good ride. I lied. I can make boost apparently but it takes a longggg time. Hold it to the floor and it takes a while but I get to 3500rpm and it started to go up, I got it to hit 10psi boost. And I can hear a leak. An air leak so I'm gonna pressurize the air to air system. I'll post up numbers at idle in a minute
Old Apr 6, 2017 | 12:04 PM
  #51
Knucks's Avatar
Knucks
Key on engine off.
Old Apr 6, 2017 | 01:04 PM
  #52
Knucks's Avatar
Knucks
Is the map no good ? I just bought it brand new aftermarket
Old Apr 6, 2017 | 01:27 PM
  #53
Knucks's Avatar
Knucks
Would a vacuum leak cause the map sensor to do that? I noticed my vacuum pump never turns off. And is there any procedure to testing the plug to make sure im getting proper voltage to the sensor. Cause if its the sensor im gonna be pissed. I just bought it the other day.
Old Apr 6, 2017 | 01:47 PM
  #54
jswartz84's Avatar
jswartz84
The vacuum pump is a seperate system. It has nothing to do with your boost problem. I'd say check your MAP fitting, clean it and retest, if problem still exists, you have a bad MAP sensor.
Old Apr 6, 2017 | 02:21 PM
  #55
Yama4fitty's Avatar
Yama4fitty
What you are seeing that is labeled as "MAP" is probably the "Boost" reading. The "Intake" PSI in the upper right corner as you are looking at it (bottom right on this page) is representing your actual MAP reading. Your MAP looks fine.
Are you using the FORD PID's that had to be added? If you are that is what happened when you added that specific PID. The Ford specific "Boost" will be added and labeled automatically as "Map."
Old Apr 6, 2017 | 02:47 PM
  #56
Knucks's Avatar
Knucks
Damn so it's not the map sensor... I pressure tested the air to air and I got no leaks.. plugged cat maybe? Buttt wouldn't that make my ebp go up?
Old Apr 6, 2017 | 02:50 PM
  #57
Yama4fitty's Avatar
Yama4fitty
Your MAP sensor is fine. It is the PID on Torque that is screwing with your head.
EDIT:
You edited the post.
Change the name on the "MAP" to Boost.
Change the name of the "Intake" PSI to "MAP" and it will help others who are reading out...and your own sanity.
Old Apr 6, 2017 | 03:09 PM
  #58
Knucks's Avatar
Knucks
Changed it up on torque. Maybe it worth taking a video of what the truck is doing. It's like it's not shifting right away, and boost is having a hard time coming up. My other truck did the same thing and it ended up being the EBP sensor. Maybe I should swap it out? Not sure if the numbers on torque are good or not
Old Apr 6, 2017 | 03:24 PM
  #59
Yama4fitty's Avatar
Yama4fitty
It's a possibility of the EBP sensor being no good. Unfortunately my Torque won't let me see EBP or Baro. My FORScan uses PSIG (gauge) versus PSIA (absolute) on the EBP so my EBP is different on FORScan.
If you unplug the EBP and drive it what happens?
Old Apr 6, 2017 | 03:26 PM
  #60
Knucks's Avatar
Knucks
Well gonna pull the downpipe and see what happens, just read this : http://www.powerstrokenation.com/forums/10-6-0l-power-stroke-technical-info/62470-05-f-350-low-boost-no-power-3.html
