Last shot
Old Apr 5, 2017 | 06:14 PM
  #31
Knucks's Avatar
Knucks
It's weird, I'll go WOT while driving and I can hear it spooling up buts it's like it won't get released, if that makes sense. I don't know how else to describe it. Any suggestions?
Old Apr 5, 2017 | 06:16 PM
  #32
Knucks's Avatar
Knucks
The only codes I got now are P0670: glow plug, p0683: glow plug code, P0299: turbo underboost
Old Apr 5, 2017 | 07:02 PM
  #33
Knucks's Avatar
Knucks
Question for you guys. I have the vgt actuator out of the truck. Can I put power at the end of the plug, and see if it will open and close or is that just a sensor?
Old Apr 5, 2017 | 07:37 PM
  #34
BLADE35's Avatar
BLADE35
ohm it out
Old Apr 5, 2017 | 08:02 PM
  #35
Knucks's Avatar
Knucks
4.2 ohms. What's spec?
Old Apr 5, 2017 | 08:05 PM
  #36
BLADE35's Avatar
BLADE35
its not open circuit
it tested good to a point
Old Apr 5, 2017 | 08:14 PM
  #37
Knucks's Avatar
Knucks
So turbo is screwed then?
Old Apr 5, 2017 | 08:17 PM
  #38
BLADE35's Avatar
BLADE35
to truley test a vgt you haveto have the ability to take control of vgt and have the gauge to measure position
Old Apr 5, 2017 | 08:19 PM
  #39
BLADE35's Avatar
BLADE35
therez a test port on turbo to measure postion as its comanded to move
didnt these guys post turbo guide pdf??
Old Apr 5, 2017 | 08:20 PM
  #40
Tideman's Avatar
Tideman
If you took the turbo completely apart. Did you "time it" back on the vane sweep?
Blade you got it. You posted same time as I.
Old Apr 5, 2017 | 08:25 PM
  #41
BLADE35's Avatar
BLADE35
i didnt see map in you pics
need it reading
Old Apr 5, 2017 | 08:36 PM
  #42
Knucks's Avatar
Knucks
I used a magnet and pulled the plunger back and forth to make sure the unison ring got a full sweep back and forth. I followed that part on dieseltechtons video. Is that what you mean by timing it?
Old Apr 5, 2017 | 08:39 PM
  #43
Tideman's Avatar
Tideman
Yes. That's it.
Old Apr 5, 2017 | 09:08 PM
  #44
Knucks's Avatar
Knucks
Im thinking maybe the catalytic converter maybe plugged? I cant think of anything else. I may put my 2006 turbo back in tommorow, just need to be put it back together. Was gonna wait till my new seal kit came in, but I need this truck.
Old Apr 5, 2017 | 10:36 PM
  #45
Knucks's Avatar
Knucks
Also wanted to mention the truck isnt blowing black smoke, so the turbo must be spinning.
