Maybe I have to do a turbo relearn? But my truck is a 2006... the turbo is a 2003. Hmmm maybe worth a try. If not I guess I'll take that turbo out and put my 06 turbo back in and see if that works.
Ebp isn't reading psi. It reads voltage and the pcm interprets the volts into psi. Ebp volts should be in the .88 range koeo. The vgt learn strategy is strictly a pcm calibration event. The 03 turbo means nothing on an 06 as far as learn strategies. The map and ebp both need to be good to get boost.
I guess I missed the other thread. Imma go look for it.
