Ford edge Plug n Play plug location
Old Apr 3, 2017 | 04:11 PM
jkryzkij's Avatar
jkryzkij
I purchased the plug and play from dealership and have an appointment to have keys coded Friday but wanted to install the unit beforehand as I have installed many remote starters in the past. I cannot find the simple plug location and cannot find instructions anywhere. Can you assist? 2014 Ford Edhe no push button start and no power rear. I already installed the hood switch.
Old Apr 3, 2017 | 04:49 PM
Pocket's Avatar
Pocket
I'm assuming you're referring to kit BC3Z-19G364-A. Should be 2 keys and a skinny black antenna with wiring in the box. Is this correct?
That antenna plugs into the TPMS, which is located just behind the rear seat panel in the driver's side. Fold down the driver's side rear seat, and pull the panel back (grab on one hand by the door, other hand at the window). You only need to pop it loose to get behind it.
Once the panel is popped loose, locate the TPMS. It will be attached to the back side of the plastic panel you popped loose. Below the wiring harness that is already plugged in, you'll find an empty plug. The antenna goes there. Plug it in, zip tie it in place, and pop the panel back. Done!
jskufan
Aug 9, 2013 12:55 AM
720Deere
6.7L Power Stroke Diesel
Oct 25, 2010 10:52 PM
Bergfurher
Jan 18, 2010 04:47 PM
78ranchero
Jan 26, 2009 08:21 PM
Joe_D
May 6, 2008 06:22 PM
