Sponsored by: Innova
Aux input plug
Old Jan 26, 2009 | 01:34 PM
78ranchero's Avatar
78ranchero
Aux input plug
2008 F250 XL. I upgraded from an AM/FM to AM/FM w/ CD, both Ford units. I want to use the aux feature of the new radio, but I need to add the input plug. When I pulled the blank panel on the lower right of the center panel where the plug would be located, I found a wire for the aux input plug. My question is whether the plug can/must be purchased with the panel attached or is it two separate parts. I got nowhere with the Ford counter guy. Part numbers would be helpful. Thanks.
Old Jan 26, 2009 | 02:06 PM
ReAX's Avatar
ReAX
If you have a harness for the radio with bare wires, then you can splice any thing into them. RCAs, 2.5mm jack, 1/4" jack, universal ipod adapter. The big thing will be finding which wires are the ground and which is right/left.
Old Jan 26, 2009 | 02:43 PM
78ranchero's Avatar
78ranchero
That is why I was sort of looking for the OEM app that would just plug in to the existing connector.
Old Jan 26, 2009 | 08:21 PM
wiingnut's Avatar
wiingnut
check into a pie adapter. I dont know if they have one for the 08 yet. look into it. Each pie adapter is specified to model years. they just plug into back of radio, you hook up power and ground. plug your device in and asjust pot for loudness level
F357
Dec 31, 2014 04:03 PM
TJ62
Nov 28, 2014 11:52 AM
galaxie641
Sep 18, 2012 08:08 PM
IABill
Jul 6, 2011 10:05 AM
Vettruck
Apr 3, 2005 08:56 PM
