Sponsored by: Real Truck
Passenger Kick Panel Removal
Old Jan 31, 2004 | 03:19 PM
jskufan's Avatar
jskufan
I wondered if anyone could tell me how to best remove the passenger side kick panel on my 2001 superduty. There is a plug I am looking for to make the clearance lights work. It looks like the kick panel continues under the door threshold. I don't want to remove any more than I have to. Thanks in advance.
Old Jan 31, 2004 | 03:41 PM
Bowcop's Avatar
Bowcop
If you pull back the carpet where your passengers feet would go, right at the firewall you will see the plug in question. if you do a search for member "hang10" he has a nice photo of this in his gallery.
99f350sd's Avatar
99f350sd
Door threshhold pops up clips are in rubber cups U can see them from underneath..remove pin in panel. Panel pulls back towards bed...
Old Jan 31, 2004 | 03:47 PM
jskufan's Avatar
jskufan
Thank you for the info. I have found the upper plug connection just above the kick panel and I'm looking for the lower plug that actually connects to power. I ordered the clearance lights factory but they have never worked. I have deducted that they may never have been plugged in.
Old Jan 31, 2004 | 04:11 PM
jskufan's Avatar
jskufan
Do you have to remove the threshold to remove the kick panel?
Old Jan 31, 2004 | 04:22 PM
Yeti's Avatar
Yeti
Yes, I believe the front of the threshold or sill plate snaps in to a hole on the kick panel, kind of locking them all together , you might be able to pull the kick panel out enough to get in there, but the sill plate comes off real easy.
Old Jan 31, 2004 | 08:21 PM
jskufan's Avatar
jskufan
This is the passenger side kick panel. Is the lower plug of the wiring harness behind here?? Does that little "button" pop off to reveal a fastener??
Old Jan 31, 2004 | 10:35 PM
99f350sd's Avatar
99f350sd
For god sakes pull that thing out and take it apart. just grab and yank straight out. There's all kinds a stuff behind there.
Old Feb 1, 2004 | 09:33 AM
jskufan's Avatar
jskufan
Sorry about all the "excessive" posting. I'm usually not that big of a wussy when it comes to tearing into something. I have already gotten more help on this thread than I got at my local Ford dealer. Today, if the temperature goes over 20 degrees, I'll go out and remove the panel, and with any luck, I'll find the lower plug and simply plug the harness in to make the clearance lights work. I just get a little apprehensive about pulling on something if I'm not sure wether it snaps off or unscrews. I didn't know if I should pry that little "circular" button off first or just pull the panel. If it wasn't so cold and wintery here, I probably wouldn't even be on the computer!
Old Feb 1, 2004 | 09:37 AM
99f350sd's Avatar
99f350sd
The plug thing is about 2 inches long and has the normal little feathers on it...for trim pins. they come out easy. pull the side panel out towards the bed it has steel clips..2 I think.
Old Aug 9, 2013 | 12:55 AM
savenow1501's Avatar
savenow1501
2003 F250 replacement driver's side kickplate panel
Please disregard my previous post. The junkyard wasn't so bad afterall. Please offer specific directions how to delete this post.
Your time is appreciated.
-Dave
Mike_Br
Dec 11, 2016 10:20 AM
MAP53
Oct 4, 2015 09:15 AM
Mustangking1
Dec 31, 2013 03:47 PM
badutahboy
Apr 24, 2011 07:46 PM
jbondi
1978 - 1996 Big Bronco
Apr 9, 2004 07:26 AM
