P0470 Question
Old Apr 3, 2017 | 08:46 AM
Raleigh234's Avatar
Raleigh234
P0470 Question
I popped code P0470 a few weeks ago. The EBP sensor had actually fallen apart. The threading was still in the bracket, but the sensor had sheared off and was only held to the truck by the electronic plug. I also found a hole in the tube. I replaced the tube, the bracket, and the sensor, and for about a week, the code went away and the truck started running normally again. However, the code is back, and she's back to a really rough idle, hard starts, hard shifts, and when starting up, small amounts of blue smoke. I looked at the plug, but it seems like it's in good shape. I've been doing research, and know that there are some tests I need to run, like testing the electrical connection, but I wanted to ask if a faulty MAP sensor can throw a P0470. I couldn't find anything about that, but I do know that MAP and EBP work together, and it seemed like all my problems are similar to a bad MAP.
Old Apr 3, 2017 | 09:18 AM
Jarrett Campbell's Avatar
Jarrett Campbell
You could unplug the MAP and see if it runs a little better. Also, I have gotten two DOA MAP sensors from Oreilley's so I would go straight to Ford for the sensor.
Old Apr 3, 2017 | 09:50 AM
oldbird1965's Avatar
oldbird1965
or Riffraff
Old Apr 3, 2017 | 11:03 AM
Jarrett Campbell
True. If you can wait for shipping, Riffraff usually has better pricing.
Old Apr 3, 2017 | 05:19 PM
Raleigh234's Avatar
Raleigh234
Alright so here is an update. I started the truck up with everything plugged in, so I could see if the arm that opens the valve moves at all. It didn't budge. So i unplugged the connector at the turbo, and it still didn't move. It looks like it is stuck closed. it also looks like its been leaking oil after close inspection. Wouldn't it throw another code, like 473 or something if there was a problem with the valve? Because after I unplugged the connector at the turbo, it still didn't show any codes other than 470
Old Apr 4, 2017 | 08:43 AM
Jarrett Campbell
You could pop your down pipe off and peek in to see if it is stuck open or closed.
If I am remembering correctly, only cali trucks throw a CEL when the valve is unplugged.
I am not sure if federal trucks throw a soft code when you unplug it.. I don't think mine has a soft code for the EBPV and it is completely deleted.
Old Apr 5, 2017 | 11:40 AM
madpogue's Avatar
madpogue
P0470 is for the SENSOR. Has nothing to do with VALVE operation. When you replaced the tube, did you confirm that the fitting on the manifold is not clogged? 'Course, even if you did, it may be clogged now.
The VALVE shouldn't close unless ambient temperature is below a certain point, something like 35F. Did you check the position of the valve by removing the downpipe? Does the exhaust sound like the valve is closing?
Old Apr 5, 2017 | 01:59 PM
Hussler's Avatar
Hussler
If the PCM sees a defective sensor (P0470) it won't try to cycle the valve. PCM uses the sensor data (back pressure) to determine if the valve is working or not. Bad sensor, it won't even try.
Old Apr 5, 2017 | 02:10 PM
madpogue's Avatar
madpogue
In that case, it should leave the valve open. Of course, the PCM uses the sensor for engine control as well, so if it's indeed getting a bad reading, that is more likely the cause of the running problem(s).
Old Apr 5, 2017 | 02:28 PM
Raleigh234's Avatar
Raleigh234
Alright, I popped the downpipe off to get a closer look. That thing is shut, and I tried to open it and it won't budge. I also discovered an exhaust leak, and oil coming out of the actuator. At this point, I'm just going to delete the system. I live in Texas, so it doesn't ever get cold enough to make me think that'll cause a problem.
While I'm in there, I figured I'd go ahead and replace all the seals and stuff on the turbo. Anything else I should do while I'm in there? I was thinking maybe up-pipes would be a good idea. I'm replacing the downpipe with a straight one and getting rid of the stock downpipe. I'm also thinking about changing out the compressor wheel and turbo housing. Both the housing and downpipe are Banks replacements, and the delete stuff is coming from Riffraff (pedestal, resistor, and outlet).
I'm big into preventative maintenance, because I hear some of this stuff isn't fun and I have no intention of ever having to do it again.
Old Apr 5, 2017 | 03:24 PM
knottyrope's Avatar
knottyrope
replace the oil rail plugs on rear of heads since you will have to room to do it with the turbo out of there. Replace the fuel 90 under the turbo pedestal.
Don't need a new turbo outlet IMO, remove the valve flap with grinder, pull the shaft out and add in a steel plug where shaft was to save you some $$$ for other stuff.
HavinaPretzel
Jul 3, 2023 09:56 AM
Deep South
Oct 1, 2014 01:32 PM
Benny2002
Jul 8, 2007 11:25 PM
amsnss
Jan 11, 2003 02:54 PM
dmanier
1978 - 1996 Big Bronco
Oct 27, 2002 04:46 PM
