swapping diff and trans
Old Mar 30, 2017 | 02:37 PM
Cobravii's Avatar
Cobravii
Hi Guys,
I have a 1950 F-47 that is real new to me.
I have visions of replacing the trans to a T5Z tremec for sure and am considering going to a 9" ford diff.
Can anyone tell me what is involved in this swap?
Thanks,
Larry
Old Mar 30, 2017 | 05:04 PM
oneye's Avatar
oneye
I'll be doing the same thing myself this summer but in an F-1. What engine?
Old Mar 30, 2017 | 05:23 PM
Cobravii's Avatar
Cobravii
stock v-8 flathead
Old Mar 30, 2017 | 06:21 PM
tip49's Avatar
tip49
Swap
You'll need to consider:
adapter plate to mount trans to engine
possible modified tran inspection plate/hump
modified driveshaft to couple trans to diff
add crossmember to support transmission
adjust diff spring perches for pinion angle
Old Mar 30, 2017 | 07:36 PM
raytasch's Avatar
raytasch
Believe Nothing
Be mindful of gear shifter position relative to the seat. I would question the need for the 9" with the T5.
Old Mar 30, 2017 | 09:33 PM
Cobravii's Avatar
Cobravii
I was only thinking 9" for ease of working on and changing ratios. I kinda get the feeling the diff on these is a weak link.....
I see some factory style cast iron bell housings on eBay. They say a T-5 will bolt to it. Any oppinions?
Old Mar 30, 2017 | 11:15 PM
ALBUQ F-1's Avatar
ALBUQ F-1
A stock "hogshead" (front half-bellhousing from a 4-sp spur gear trans) can be redrilled to accept a T5. Some T5's may bolt directly but there are other factors such as front bearing retainer diameter.
A '50 F-1 would have come with a 3.73 rear axle, or the optional 4.27 or (rare) 3.92. The 3.92 with a T5 is about ideal for a stock flathead. 1st gear with the S-10 T5's is pretty useless tho.
Here is a very well written and thorough article on all the work involved (although it doesn't cover the necessary butchering of the stock trans crossmember on 48-52's):
TECH: Ultimate T-5 Article | The H.A.M.B.
Old Mar 30, 2017 | 11:36 PM
Cobravii's Avatar
Cobravii
Good info!
I agree that 1st gear on a T-5 is useless but mine is a T-5Z which has a high first gear and makes it more functional.
Thanks for the info on the gear ratios. Did they ever come as a posi?
superduty steve
General Automotive Discussion
May 2, 2019 03:57 PM
sgary
Jul 14, 2012 12:50 PM
F.ROCK
Oct 16, 2008 05:49 AM
STEVE1103
Flathead V8 & Flathead 6
Feb 26, 2006 07:19 AM
gar
1947 and Older Ford Trucks
Nov 23, 2002 02:14 PM
