adapter plate to mount trans to engine
possible modified tran inspection plate/hump
modified driveshaft to couple trans to diff
add crossmember to support transmission
adjust diff spring perches for pinion angle
I was only thinking 9" for ease of working on and changing ratios. I kinda get the feeling the diff on these is a weak link.....
I see some factory style cast iron bell housings on eBay. They say a T-5 will bolt to it. Any oppinions?
A stock "hogshead" (front half-bellhousing from a 4-sp spur gear trans) can be redrilled to accept a T5. Some T5's may bolt directly but there are other factors such as front bearing retainer diameter.
A '50 F-1 would have come with a 3.73 rear axle, or the optional 4.27 or (rare) 3.92. The 3.92 with a T5 is about ideal for a stock flathead. 1st gear with the S-10 T5's is pretty useless tho.
Here is a very well written and thorough article on all the work involved (although it doesn't cover the necessary butchering of the stock trans crossmember on 48-52's): TECH: Ultimate T-5 Article | The H.A.M.B.
