trans and diff swap
Old Jul 13, 2012 | 10:31 PM
sgary's Avatar
sgary
trans and diff swap
I'm having no luck finding a side shift trans for my boss' 51 F1. Will a passenger car trans fit? How about the diff, gear ratio?
Old Jul 14, 2012 | 10:04 AM
tinman52's Avatar
tinman52
Welder User
How about more info? Which engine? Which rear end? Keeping it stock or modifying it?
I have an original side shift trans I would part with.....not sure what you are looking for though.
Old Jul 14, 2012 | 10:35 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Car trans' have a smaller input shaft diameter compared to trucks.
Old Jul 14, 2012 | 10:50 AM
sgary's Avatar
sgary
The engine is an 8BA flathead and the diff looks like a 9". The truck is going stock. This is my first Ford build and I don't know what interchanges. How much do you want for the trans? Do you know the approximate weight so I can figure out the shipping cost?
Thanks guys.
Old Jul 14, 2012 | 12:50 PM
f5fordgirl's Avatar
f5fordgirl
The ford car trans through 48 had closed drive shaft, I know from 46 up, trucks had open drives. If you can find a side shift car trans or case, swap the output shaft and mount, and you're ready to go. The smaller input shaft on cars started with the 49 models.
Cobravii
Mar 30, 2017 11:36 PM
MarkG.
Oct 19, 2012 02:47 PM
