Auto stop-start disable and other dash issues
I haven't tried both keys, I've only used one from day 1. I can't imagine using a different key fob causes codes, or messages in the FordPass app. And the dash has saved the settings on a handful of restarts. More often than not however, it resets on each key cycle.
The other interesting thing, the SA kept asking if I ever saw the MIL. I wonder if those codes /should/ have been lighting up the MIL, but b/c of the IPC problem, it wasn't. I don't know if since it wasn't an engine issue per se, that the MIL wouldn't get set. But you'd think the brake issue would have caused something to light up on the dash.
So each of my FOBs somehow has different settings, whether that is right or wrong, that's way mine is.
Josh
Josh
726-48-02 x*xx xxxx xxxx Slave Exists BMS Cfg: 0=absent, 1=present disabled auto start/stop - AirborneApe's
Mine has been off for 3 months now. Its never has re-engaged.
