Auto engine shut off!!!
Old Apr 18, 2017 | 05:57 PM
Anibal Medina's Avatar
Anibal Medina
So I was looking to enable manual regeneration on my truck and came across this in IDS the ability to change the time the truck auto shut off when idling. I changed mine to 5 minutes so I can use it like a turbo timer it gives you a warning before it shuts down also if it's in any gear it won't shut down. what you guys think? Useful?
Old Apr 18, 2017 | 09:41 PM
mothnuts's Avatar
mothnuts
I'm thinking "No Shutdown"
Old Feb 3, 2018 | 10:25 PM
Bill Moulton's Avatar
Bill Moulton
No Shutdown is an option in settings on the dash.
It just has to be selected each time you want to leave it running.
I have used it when I want to keep the a/c on for my dog if I go in someplace quick.
Old Feb 5, 2018 | 10:12 AM
stewy604's Avatar
stewy604
I believe mine (6.7) is 30 mins for auto-shutdown. If I had my wish, it'd be disabled altogether.
Old Feb 5, 2018 | 03:26 PM
Bill Moulton
I think it is called Auto off or something like that in settings.
You just have to uncheck it each time you want to leave it running.I'm not sure
I would want it to be switched off all the time even if it was an option.
I'm not used to the push button start/stop yet and have left it running more than once.
Old Feb 5, 2018 | 07:46 PM
aapulask's Avatar
aapulask
This is NOT a "cool down" feature at least for those of us that still need a key. Keyless I'm not sure. Think of it as an anti idle feature (probably best for fleet owners). Walk away with the key in the ignition, engine running, and in park the truck will shut off in the preset amount of time even if you lock the doors.
Old Feb 6, 2018 | 07:42 AM
DevilDog556's Avatar
DevilDog556
Even all of our tractors at work have the anti idle feature...mine shuts off after just a couple of minutes.
Old Feb 6, 2018 | 08:57 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
It's emissions related: an example is CARB has a 5 minute max idle time on most vehicles over 10k#. Most places are not that strict, but Ford built in various options to pass whatever state requirements are imposed on sale.
https://cdllife.com/2014/idling-laws-state/
Anyone remember 49-state emissions and 50-state being an option on the window sticker?
Old Apr 27, 2019 | 01:29 AM
tanswell's Avatar
tanswell
Dude
Dude PM me or give me your email you might be my saving grace.
Old May 2, 2019 | 10:54 PM
tanswell's Avatar
tanswell
Can you go like two minutes
Can you go as low as two minutes?
Old May 3, 2019 | 01:38 AM
Evergreen03's Avatar
Evergreen03
But you’re intent is to use as a turbo timer? So you plan to leave your keys in the truck?
Old May 3, 2019 | 10:22 PM
KCRebel's Avatar
KCRebel
I disabled the auto off feature in the dash as described above and during same running engine session I still got the same alert after how many ever minutes stock settings that engine would shut off. Honestly was disappointed it is even an option to select since it doesn't work anyways.
Curious if anyone has actually tested their trucks to see if disabling the auto off in the dash works?
Maybe I did something wrong?
Old May 5, 2019 | 10:07 PM
Ian123's Avatar
Ian123
If he has push button start, he can just take the keys with him and lock the truck and it will turn off 5 minutes later
Old May 7, 2019 | 04:56 PM
tanswell's Avatar
tanswell
Turbo timer
I parked up, and took my keys game back 40 min later and it was still running (enabled)
18SD_Lariat
Mar 27, 2022 03:10 PM
TalleyHo
2015 - 2020 F150
17
Dec 12, 2017 07:44 AM
Tomc750
Sep 4, 2017 04:57 PM
Aus56
Oct 28, 2015 01:58 PM
peterbilttrucker
Utah Chapter
Apr 20, 2009 11:34 AM
