Replace injectors or clean spool valves?
Old Mar 29, 2017 | 02:58 AM
  #31
Yahiko's Avatar
Yahiko
If you can feel a that a spool valve is sticking then that injector
would be DEAD. The spool valves move from end to end in
milliseconds time.
Old Mar 29, 2017 | 08:00 AM
  #32
2006powerstroke90's Avatar
2006powerstroke90
Gotcha okay, but if this is the issue I should notice some kind of drag with the spool valve?
I am going to do it either way this weekend....
Old Mar 29, 2017 | 11:46 AM
  #33
KC Excursion's Avatar
KC Excursion
My experience: Fought the stiction issue for 2 years until I fixed it.. Hot Shots helped for a long time along but the the problem continued (also run full synthetic oil.) I was able to determine which injectors were the problem by shutting off each injector via software (Auto Enginuity - I'm neutral on recommending it)
I thought why not try cleaning the spool valves. I took apart the 3 suspects ones, mechanically and ultrasonically cleaned the spool valves. Re-installed, ran better but not a magical fix. Cold EOT running rough problem was still present until 130 on EOT.
Changed the 3 injectors with OEM remanufactured - dramatic improvement. So much I went ahead and changed out the other 5. The truck runs, starts, beautifully now at any temp.
For me, I would go directly to re-mans and skip the cleaning step.
Old Mar 29, 2017 | 01:01 PM
  #34
2006powerstroke90
I would agree about just replacing them all at just be done with it.....but for half a days labor I think I am just going try the cheaper way first granted it usually doesn't work that way but the truck just runs so damn good when its warmed up.....Its worth a shot......on the scanner is showed injector #6 acting funny when it was cold so I am going to pay extra attention to that one
Old Mar 29, 2017 | 04:24 PM
  #35
Yahiko's Avatar
Yahiko
You should not be able to feel anything really.
It's a fine file on the spool.
I am guessing at this point but I have a feeling that the spools
are honed into the housing to reach a given tolerance during
the assembly process.
Old Mar 29, 2017 | 09:33 PM
  #36
2006powerstroke90
Just wanted to give an update. I tore into the driver side tonight since it has the most crap to move out of the way looks like that side has 2 reman injectors in it.
The spool valves on the 2 (newer remans) moved easier by finger than the 2 other ones. After I cleaned them it definitely felt like I noticed an improvement, maybe my head is telling me that's what I want to feel? So I got them all re o ringed back up ready to go in. I hope I didn't leave the bolt to loose or to tight on the actual injector itself.
I really like working on this truck VS the 05+ so much easier to remove the HPO rail, that OTC disconnect tool I got worked like a charm.
I attached a couple pics
On the actual spool valve pic you can see the before on the left and after on the right. Nice and shiny and clean
Old Mar 30, 2017 | 03:54 AM
  #37
Yahiko's Avatar
Yahiko
2nd photo down. Is that a crack I see on the left hand side
of the injector by the solenoid coils?
Old Mar 30, 2017 | 07:55 AM
  #38
2006powerstroke90
It must of been a piece of lint of something....I looked this morning and it wasnt there...
Old Mar 30, 2017 | 11:43 AM
  #39
WatsonR's Avatar
WatsonR
That's a mark in the injector, look carefully, you can see it just by zooming in.
Old Mar 30, 2017 | 01:52 PM
  #40
2006powerstroke90
I think it was something sitting on the injector. Here's better pics
Old Mar 31, 2017 | 07:02 PM
  #41
2006powerstroke90
Well truck is all back together and everything was going GREAT
Until.....I lost high pressure oil and stalled out.
ICP building about 130PSI IPR is 84.* %
Hopefully the IPR is gummed up from crap falling into the heads while working on it.
Old Mar 31, 2017 | 07:23 PM
  #42
WatsonR's Avatar
WatsonR
Have you ran it?
Old Mar 31, 2017 | 07:28 PM
  #43
2006powerstroke90
Yeah, I was driving it when it died like someone shut off the key.
Old Mar 31, 2017 | 09:37 PM
  #44
2006powerstroke90
Well I got home pulled the IPR and it was perfect. Pulled the valve covers to check for a HPO leak somewhere nothing.
So I am thinking 2 things
My HPO fried bleeding the oil system.
Or could it be the ICP sensor itself?
Old Mar 31, 2017 | 10:37 PM
  #45
Yahiko's Avatar
Yahiko
Check and make sure that you don't have cracked
fittings on the oil disconnects of the rail.
stevorino
Jul 24, 2017 09:08 PM
brandon.edwards
Feb 1, 2013 01:07 PM
63DH8
May 5, 2011 06:10 PM
desertt5
Feb 17, 2011 10:20 PM
WH90
Mar 6, 2009 02:57 PM
