My 91 Crew Cab Dually has "questionable" power assist for the brakes. I'm trying to figure it out and I'm afraid I might have.
I tested the Vacuum at the Tee on the firewall and I had 5-10. I tested it at the pump (line direct from pump to gauge) and have 20 at idle.
I was under the dash today and I noticed a slight hissing sound. I pressed the pedal by hand and it stopped for a moment before resuming the hiss. It was a press and hold, not press and release.
I'm thinking my booster is leaking. What are your thoughts?
I want to do a hydroboost swap but it isn't in the cards right now. I'd consider it if I wasn't going to have to change out the pedal too, I found a used booster for $60.
I also will be installing an old hydraulic actuated trailer brake controller and need to order a tee for the line. Is the rear line at the master cylinder for the rear brakes? I think I read it's 7/16 thread but I want to get the right part the first time.
remove the vacuum line to the booster and block it. see if vacuum at the tee on firewall raises or stays low. if it stays low it is somewhere else. if it raises, the booster is bad.
Even with the slight air noise under the dash? I'll check it per your suggestion but the only other thing hooked up is the HVAC controls fwiw.
Brake line fittings are a double flare fitting I believe. They have their own size. Mom and pop auto parts stores normally have exactly what you need but most importantly know what you're looking for. I never try to find weird fittings at a run of the mill auto parts store
There's a reason they no longer make trailer brake controllers that depend on a hydraulic line, which runs under very high pressure and will cause you to lose your rear brakes if it fails, into the cab. Even the cheapest modern electric controller will be much safer.
Actually they stopped making them because they aren't compatible with ABS. They are a much better way to control the brakes than even a decent add-on electronic one, and far far superior to a cheapo electronic. The cheapest ones use a timer and just increase braking while the vehicle brakes are applied, the better ones have a pendulum to sense how hard you are braking, and apply the trailer brakes accordingly.
The new Ford integrated ones read the brake system pressure electronically and apply accordingly, so basically an electronic version of the tap style system.
Having towed with all three of the add on systems, I'll take a hydraulically actuated one any day. In fact I have one sitting waiting for my truck to be ready.
I know they're double flare. Unfortunately I've replaced plenty of lines living up here in the rust belt. Wish we had a good Mom and Pop parts house around here!
replace the steel lines with the alloy lines when they go bad and you will never have to replace them again.
Yeah but that doesn't help with everyone else's cars! In the last few months I've replaced brake lines on my brother in law's Chevy, my Father in law's Dodge, my grandmother's Buick.... Oh, and bent new fuel pressure lines from 3/8 steel for that same Buick.
