Braking Issue
Old Sep 13, 2011 | 05:47 AM
JTS1975's Avatar
JTS1975
Braking Issue
I have a 1996 F350. I was having a soft pedal about 6 months ago so I replaced the vacuum pump, brake booster, master cylinder, rear wheel seals, rear brakes, etc. Well a couple of weeks ago the vacuum pump went bad. I replaced that again and I was having an issue with the pedal going down fine the first time, but it you tried to brake again the pedal was hard to push down. I replaced the brake booster as well thinking that maybe the issue and it was not. I bleed the hell out of the brakes and that is not the issue either. Any other ideas? Like I said brake pedal works fine the first time and as long as you drive a ways before braking again it works, but if you have to brake quickly you literally have to stand on it to get it to stop. Thanks.
Old Sep 13, 2011 | 07:28 AM
fordpride's Avatar
fordpride
Sounds like you got a bad VP
Old Sep 13, 2011 | 08:06 AM
Talyn's Avatar
Talyn
Did you replace your booster with a zero loss booster?
It might be possible you have a vacuum leak someplace, and thats the cause of your pump working a bit to hard and it going out.
Old Sep 13, 2011 | 08:10 AM
Ken_C's Avatar
Ken_C
does the brake light in the dash come on? sounds like not enough vacuum to me
Old Sep 13, 2011 | 09:35 PM
JTS1975's Avatar
JTS1975
Thanks for the reply. As a matter of fact the brake light in the dash does come on.
Resendiz
Oct 8, 2015 05:36 PM
PStruwing
Dec 23, 2012 10:16 PM
soccersmom
23
Aug 14, 2011 05:31 PM
FEFD17
Nov 8, 2007 01:39 PM
jarrott
Dec 31, 2003 08:29 PM
