Hitch height set up advice needed...
Old Mar 17, 2017 | 11:54 PM
Metal twister's Avatar
Metal twister
So I acquired a really nice cobra sandpiper 5'er trailer built in 93. I didn't like the lack of side to side articulation that the hitch that came with the trailer was lacking. I purchased a very nice used Husky 16000 lb hitch with the full articulating head and installed it this evening. My question is how high above the top of the bed should the trailer be to insure that the trailer doesn't kiss the top of my bed sides with the side articulation?
The truck is a 2001 7.3 f350 Sduty cc 8' bed with a leveling kit just installed. I'm thinking I will have to flip the trailer axles before going to far. Any advice would be greatly appreciated. Thanks in advance.
Old Mar 18, 2017 | 02:30 AM
cyncwby's Avatar
cyncwby
5 to 6" above the rail should do it.
Old Mar 18, 2017 | 07:25 AM
RV_Tech's Avatar
RV_Tech
Agree, but I think it is easier to use Lippert Correct Track kit, which will give you an extra 2" of lift if you need it along with opportunity to check you shackles for wear while you have things apart.
Steve
Old Mar 18, 2017 | 08:22 AM
69cj's Avatar
69cj
Steve
Hopefully his shackle pins are lubeable or their probably ready for replacement. My non-lubeales were pretty much shot by 30,000 miles.
Old Mar 18, 2017 | 08:24 AM
RV_Tech's Avatar
RV_Tech
I think it is unlikely they can be lubed.
Steve
Old Mar 18, 2017 | 09:50 AM
P.Bronner's Avatar
P.Bronner
I consider 6" to be minimum. In various places I've seen 5" stated as being acceptable, but in the real world it'll probably get you in a bind, literally.
Old Mar 18, 2017 | 10:43 AM
Metal twister
Got it guys... Thanks so much for the help as I'm sure this has been gone over a bunch of times here. Now I need to do some homework and find out what this Lippert device is and double check grease points... Thanks again
Old Mar 18, 2017 | 03:47 PM
69cj's Avatar
69cj
Lubeable pins and shackles with bronze bushing can be had for under 50 per axle. Cost me just under a 100 for everything on a tandem 5er. Moryde is the brand you want.
Old Mar 18, 2017 | 03:52 PM
Metal twister
Perfect... Thanks
bcnu53
Jul 6, 2020 09:02 PM
77mud
All Things Towing
Mar 4, 2013 05:39 PM
Ack226
2009 - 2014 F150
Jun 9, 2009 05:48 AM
hairboy
All Things Towing
Apr 27, 2005 05:42 AM
odie780
All Things Towing
Dec 1, 2002 04:19 PM
