5'er VS G-Neck???
Old Jun 27, 2002 | 10:13 AM
odie780's Avatar
odie780
5'er VS G-Neck???
I now have a 37' 5er and love the way it pulls. I am however in tha market for a closed trailer to work out of. I have never pulled a goose neck and was wondering what diferances would be?
Old Jun 27, 2002 | 10:45 AM
textruckr's Avatar
textruckr
5'er VS G-Neck???
For an enclosed utility trailer, you really can't beat the gooseneck. It has a higher degree of articulation so you don't have to worry about damaging the top bed rails when you go over unlevel ground. If you choose the foldaway or turnover style ball, the bed is left open when you don't need the hitch (and it only takes 5 seconds to access the hitch).
I prefer the gooseneck style, and would recommend it over a fifth-wheel hitch any day!
Texas Truck - r
Old Jun 27, 2002 | 05:16 PM
Jimjdb1's Avatar
Jimjdb1
5'er VS G-Neck???
Sorry Texas, I perfer the 5-er. Just my opion.
Jim
Old Jul 15, 2002 | 07:04 AM
kbmc4's Avatar
kbmc4
5'er VS G-Neck???
The question is what is the difference in the way they pull none. both will damage the bed if there is not enough clearance when going over unlevel ground say a ditch
Bryan
Old Nov 8, 2002 | 08:36 AM
86Betty's Avatar
86Betty
5'er VS G-Neck???
JC Whitney sells a 5th wheel hitch that mounts on rails in the bed that can also be used to mount a removeable gooeseneck hitch. Pull a couple pins, pull out the fifth wheel hitch, pop in the ball for the goosenck, and you'd be set for either trailer.
Old Dec 1, 2002 | 12:49 PM
PSD_Power's Avatar
PSD_Power
5'er VS G-Neck???
I have both on my truck and like both just the same. Easier to hook up the fith wheel though. Check out my gallery I have a picture of a pop-up goosneck hitch. It is great. stays out of the way and I didn't have to cut a huge hole in my bed like some of them are. Just a 3" hole in the bed. Took me a couple hours by my self to do.
Justin
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=9313&.jpg
http://66.179.41.42/gen1/build/realgeneral.jpg
2002 F-350 SC LB 4X4 6SPD PSD. 3.73 gears. 2.5" leviling kit. K&N air filter. Rhino lined Bed. Prodigy trailer brake controler. 35x12.5x16.5 BFG A/T. 16.5x10 ultra wheels. pop up gooseneck hitch and firestone airbag spring helpers. Reese fifth wheel hitch for my new toy hauler. Superchips microtuner.
Old Dec 1, 2002 | 04:19 PM
2Wise4aGM's Avatar
2Wise4aGM
5'er VS G-Neck???
