Hitch height set up advice needed...
So I acquired a really nice cobra sandpiper 5'er trailer built in 93. I didn't like the lack of side to side articulation that the hitch that came with the trailer was lacking. I purchased a very nice used Husky 16000 lb hitch with the full articulating head and installed it this evening. My question is how high above the top of the bed should the trailer be to insure that the trailer doesn't kiss the top of my bed sides with the side articulation?
The truck is a 2001 7.3 f350 Sduty cc 8' bed with a leveling kit just installed. I'm thinking I will have to flip the trailer axles before going to far. Any advice would be greatly appreciated. Thanks in advance. |
5 to 6" above the rail should do it.
Agree, but I think it is easier to use Lippert Correct Track kit, which will give you an extra 2" of lift if you need it along with opportunity to check you shackles for wear while you have things apart. :)
Steve |
Originally Posted by RV_Tech
(Post 17042125)
Steve |
I think it is unlikely they can be lubed. :(
Steve |
I consider 6" to be minimum. In various places I've seen 5" stated as being acceptable, but in the real world it'll probably get you in a bind, literally.
Got it guys... Thanks so much for the help as I'm sure this has been gone over a bunch of times here. Now I need to do some homework and find out what this Lippert device is and double check grease points... Thanks again
Originally Posted by Metal twister
(Post 17042543)
Perfect... Thanks
