Gooseneck Chains?
Old Mar 19, 2017 | 02:48 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Actually we are using the wrong post to be carrying on about the pin weight, box or anything OTHER but using chains. The moderator should move this discussion to the appropriate thread.
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
With my AUH, I have removed it and put it in the passenger seat or extra cab space in order to get something large into the bed.
I was going to get the Companion hitch as well, but took a chance on the AUH and will never own a different style hitch.
Old Mar 19, 2017 | 03:16 PM
P.Bronner's Avatar
P.Bronner
Originally Posted by BPofMD
What exactly are your structural concerns ? To the truck or the trailer? If you use the aluminum Anderson you are speaking of 40 # or less to remove it from the bed. Yes, the rails will remain, but so what? They don't bother using the bed that much at all.... surely not as much a one HEAVY Companion! Don't know if your truck has the ability to have the Ford puck system for the Goose ball - but if it does, the goose version of the Anderson leaves NOTHING in the bed.
Nevermind, you're obviously not tracking with what I'm saying. I made it quite simple.
Old Mar 19, 2017 | 03:38 PM
Ferguson65's Avatar
Ferguson65
Originally Posted by Chuck's First Ford
Question::: does the shoe of a standard 5th wheel hitch CARRY!! much weight??.. as if the PIN hold most of the weight in the Claws???? UP/Down weight.. not just pull/brake weight.
The jaws of a 5th wheel carry no "pin" weight. All they do is hold the pulling/braking weight. The groove machined into the kingpin is locked into the jaw to keep it from popping out the top.
P Bronner, Lippert approves the goosebox for use on their frames and it will not void the warranty. That's good enough for me. The goosebox eliminates the "lever" that the adapter creates by using a pin box designed to go to the bed floor.
I have no skin in this game. I use a Reese elite hitch. I would use a goosebox. I wouldn't use an Andersen, but I'm not going there.
To the OP and to get back on track...........If using a ball hitch, you need chains. Doesn't matter if the ball is on the bumper, receiver, goose or Andersen. If it's a ball connection it needs chains.
Old Mar 19, 2017 | 04:51 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Ferggy...in MD you do NOT need chains when using the Anderson. So long as your vehicle is registered in MD you don't need it in any state you drive in.
jtackett
All Things Towing
48
Aug 7, 2013 08:55 AM
darren32
6.7L Power Stroke Diesel
Aug 29, 2011 08:39 AM
Old Rusty Wrench
All Things Towing
Oct 15, 2009 03:54 AM
dave98
All Things Towing
Apr 1, 2005 11:31 AM
fords_forlife
Wisconsin Chapter
Oct 30, 2004 08:20 AM
