redline mod did nothing
Old Mar 12, 2017 | 03:16 PM
eckart's Avatar
eckart
Hi Ive got a late 99 with a 6637 airfilter stock muffler delete didn't have a cat. delete pipe sure looks like a 3 inch not 3.5. just ordered a 4" turbo back mbrp. It has a flashpac...ya ya ya I know.... that's always in the light tow mode. I have a pyro and use gauge pro to check boost. It makes 21 lbs of boost. thought I would try the redline mode but nothing changed 21 lbs of boost pulling a big long hill before and after. fairly fast to 2o-21lbs and sitts there. waste gate? cannt hear any blow off. Or do I need a really boost gauge? Or is something up? Thanks for any help.
Old Mar 12, 2017 | 06:25 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Does the truck seem to de-fuel at 22 PSI? If your turbo is 100% stock, you won't see much more than that.
Old Mar 12, 2017 | 07:28 PM
eckart's Avatar
eckart
keeps pulling hard just doesn't build more boost.
Old Mar 12, 2017 | 07:32 PM
eckart's Avatar
eckart
stock turbo. should I look a changing it? its my hunting fishing pull my 25' traveltrailer truck. trying to keep egt down. its not a dd. I do plan on keeping as long as possible. just love it.
Old Mar 12, 2017 | 08:04 PM
jhl3's Avatar
jhl3
Have you built a boost leak detector and tested for leaks?
Old Mar 12, 2017 | 10:28 PM
eckart's Avatar
eckart
no I have not. I was thinking that to buit if a stock turbo can only push 21 lbs maybe I don't have a problem. Ill still check for leaks. thanks
Old Mar 13, 2017 | 12:11 AM
Bonanza35's Avatar
Bonanza35
No, with tunes you can go higher. I know with the 1.0 outlet and the WW you can hit 30psi.
Old Mar 13, 2017 | 12:24 AM
The Brad's Avatar
The Brad
Is there a boost fooler on the map line? That may be limiting your OBD2 boost reading. I never see over 22psi on my Torque Pro app, even though my analog gauge sees over 40psi.
Old Mar 13, 2017 | 06:14 AM
Pocket's Avatar
Pocket
Why are you expecting more boost if you're in a light tow mode?
Pulling the red line from the wastegate actuator doesn't stop the wastegate from opening up. All that mod does is prevent the wastegate from opening sooner at lower boost pressures.
At higher boost pressures, you have rapidly increasing exhaust pressure. The stock wastegate isn't strong enough to overpower excess exhaust pressure, and it will still open.
Then on top of that you're only adding slightly more fuel than stock on a light tow tune. The stock turbo on a stock tune will see 16-18 psi of boost. Add just a tiny bit of fuel, and 21 psi sounds about right.
IMO, don't chase a phantom problem.
Old Mar 13, 2017 | 06:33 AM
Tugly's Avatar
Tugly
When my truck was stock (with exception of air in/out), I reached 22 PSI on stock tuning and the red line mod. It's possible the flashpac tricks the MAP signal, or maybe there is a boost fooler of one design or another.
Old Mar 13, 2017 | 07:01 AM
Sous's Avatar
Sous
FTE Emeritus
With a 100% STOCK turbo 22 PSI is good. With a modified stock turbo (billet wheel, outlet, etc) 28 PSI is about your max before the turbo becomes very inefficient.
Old Mar 13, 2017 | 08:13 AM
eckart's Avatar
eckart
light tow is the 2nd most powerfull tune. I have never tried the performance tune. But it is time to upgrade some stuff. I was just expecting something to change with the redline mod. no I don't have a boost fooler.
thanks for the help
Old Mar 13, 2017 | 08:29 AM
Tugly's Avatar
Tugly
...no I don't have a boost fooler....
I thought that too, until I discovered a strange black wire connected to my MAP signal line. I'm not saying this is your case, but if you're not the original owner....
Fear no Hill
6.7L Power Stroke Diesel
18
Mar 16, 2013 08:36 AM
hedhntr
May 23, 2011 12:13 AM
brickie
Sep 11, 2010 12:11 PM
nhill2090
Jan 15, 2008 09:17 PM
me235
Mar 23, 2007 02:06 PM
