boost flutter
Old Jan 14, 2008 | 11:16 AM
nhill2090's Avatar
nhill2090
boost flutter
I had mentioned this in another thread but i think i was misunderstood. That and it was on another subject so it sort of got pushed aside.
Basically, my boost gauge functions nicely, i hit about 25-26 at WOT. However, once i get up there above 15 or so, the needle moves real quickly between the numbers. For example, if im at 20 lbs of boost, the needles moves real quickly back and forth from like 19-20. the lower pressures are usually fine unless im on a hill for long periods at about 10 psi or so, then it will do it there as well. Do we have any ideas to this problem/
Thanks guys
Old Jan 14, 2008 | 11:35 AM
SolidGround's Avatar
SolidGround
That's about as close to surging an early '99 you'll ever hear about.
Nothing wrong, just the turbo playing catch-up with itself.
Old Jan 14, 2008 | 10:41 PM
nhill2090's Avatar
nhill2090
thanks jet it was making me crazy
it was mind games, i changed out the T fitting and used new clamps and it seemed to disapper then come back
then i took off all my intercooler boots and cleaned/hairsprayed them, gone but came back
i guess its normal after all
Old Jan 15, 2008 | 05:37 AM
ron's power stroke's Avatar
ron's power stroke
mine did this..it was in and out play on the turbo wheel...may not be your case..but after i put the 01 turbo on with the ww.. my gauge is steady all the way to 27..
Old Jan 15, 2008 | 07:27 AM
nhill2090's Avatar
nhill2090
ron, last time i checked several weeks ago, my turbo was was tight as can be, no play at all
Old Jan 15, 2008 | 07:33 AM
ron's power stroke
it was just a thought... have you checked the map line for leaks??
Old Jan 15, 2008 | 10:40 AM
nhill2090's Avatar
nhill2090
how would i go about checking the map line for leaks
Old Jan 15, 2008 | 11:05 AM
SolidGround
You can visually inspect it, rub it, caress it but don't take it too far!
IMO, you're wasting your time. Like I said, "that's about as close to surging an early '99 you'll ever hear about."
They just don't surge, that little fluctuation you see now and again is will be about it. Nothing you'll ever hear or feel.
Old Jan 15, 2008 | 11:24 AM
nhill2090's Avatar
nhill2090
thanks jet, i think ill leave it alone at that
Old Jan 15, 2008 | 03:02 PM
ron's power stroke
i would build a boost leak checker and look for leaks..but thats me..my ealry turbo never surged..not even close till the bearing went bad ..i pulled my brothers 35ft 5th wheel camper up many mountians around here and i never got any surge.. but thats me..im fussy when it come to my truck...if it didnt surge before..then it shouldnt be now..if fixing the boots helped it for a while..then id be looking into it more..
Old Jan 15, 2008 | 09:17 PM
nhill2090's Avatar
nhill2090
i truthfully am not sure if it helped it could have been my inmagination
but tonight i tightened them back up, they needed it (the boots)
