Turbo Boost?
Old Mar 13, 2013 | 10:03 PM
Fear no Hill's Avatar
Fear no Hill
Turbo Boost?
Hi All,
What's the max turbo boost you guys get under full throttle with a load? I finally got a 1,000 miles on the odometer and towed the 30' 5er for the first time today and only got around 20-22 psi boost up a 6% grade, WOT. I managed to get to 70mph but couldn't accelerate beyond that.
This normal? Boost gauge goes to 40psi, what's up with half of that?
Regards,
Doug
Old Mar 13, 2013 | 10:10 PM
stro1965's Avatar
stro1965
That's about the most I've ever had too.
Old Mar 13, 2013 | 10:29 PM
kper05's Avatar
kper05
21 PSI is my record.
Edit:
Maybe it was 22...now I can't remember.
It's in the "well it happened" thread somewhere...
Old Mar 14, 2013 | 05:06 AM
2ndStroke's Avatar
2ndStroke
I'm guessing the cab and chassis share the same gauge as our trucks, as they hit higher psi?
The stock programming must be set to defuel around the 20 psi. I've hit 30+ with my truck tuned.
Old Mar 14, 2013 | 06:24 AM
Hdslider's Avatar
Hdslider
22 is my record. Pulling. 16, 000 lb trailer.
Old Mar 14, 2013 | 06:43 AM
Fear no Hill
There seems to be plenty of power on tap. I guess I was surprised that the boost flattened at 22 psi. Towing the 5r is a joy now compared to my former truck. Looking forward to first towing trip in a couple weeks.
Regards, Doug
Old Mar 14, 2013 | 06:56 AM
Olds69442's Avatar
Olds69442
I see 23psi in certain conditions.
Old Mar 14, 2013 | 07:33 AM
blue oval fan's Avatar
blue oval fan
30+ psi with H&S makes me ! but yes, before tuned usually didnt see over 20ish
Old Mar 14, 2013 | 08:47 AM
SavageNFS's Avatar
SavageNFS
In case anyone researches this, I'm going to post it here as well as in my DPF on tuning thread. You don't get the same amount of boost pressures with DPF on tuning as the guys that are deleted. I've seen 26-28 fairly often, but I've only seen 28psi+ when I'm REALLY getting into it and I've only seen 30psi once and I have the burnout to prove it.
Old Mar 14, 2013 | 11:10 AM
Kjewer1's Avatar
Kjewer1
VGT and wastegates complicate it somewhat, but in simple terms more fuel is more boost for most diesel engines, so once you use a tuner it goes up.
I see low 20s on my truck as well (stock). I like that the stock gauge has enough range to cover a pretty solid tune down the road.
Old Mar 14, 2013 | 09:20 PM
Fear no Hill
20-23 psi just seems low for a 400hp engine, maybe not. I'll reserve judgement on the power of these engines until I get a few towing trips under my belt.
Another question - has anyone experienced a bit of shuddering when starting from a stop under load? I had this happen a few times and don't know if it's a concern or not. Once I got over 10-15 mph it went away.
Regards, Doug
Old Mar 14, 2013 | 09:29 PM
Chad149's Avatar
Chad149
Regards, Doug
Mine does this too. I believe it's a little bit of axle wrap under the high torque load in first second gear. Research here will.get responses of adding airbags to help. I'm debating options, I may add a leaf if I conclude it's axlewrap.
Old Mar 15, 2013 | 07:27 AM
SavageNFS's Avatar
SavageNFS
Traction bars will also help with axlewrap...
Old Mar 15, 2013 | 08:12 AM
720Deere's Avatar
720Deere
Why do people equate boost pressure with horsepower? High pressures do not always equal more power. The volume of air flowing is just as important as the pressure and sometimes high pressure is simply a result of a constrictive intake path.
Old Mar 15, 2013 | 08:24 AM
Kjewer1's Avatar
Kjewer1
Engine displacement is a big factor in boost required for a certain horsepower. Here's some quick math that ballparks the lower boost required with the bigger engine. IIRC, my 6 liter made about 26 psi to make 376/790 at the wheels.
-Divide 6 liters by 6.7 liters to get a ratio on the displacement change. .90
-Multiply 6 liter absolute pressure (26 plus 15) by that ratio to get 6.7 liter PSIa (41x0.90). 37 PSIa
-Subtract 15 psi to get back to gauge pressure (37-15). 22 PSIg.
There are other factors so this won't be exact, but displacement is a big one. The result looks pretty close to me, if my memory of the 26 psi is correct.
