max egt's?
Old Mar 24, 2017 | 06:23 AM
  #31
KES08's Avatar
KES08
Originally Posted by BOHAWG175
If the Turbo is not forcing air into the engine the engine is sucking air which causes a vaccuum. A negative reading on a boost gauge is basically telling you how much vaccuum your engine is pulling. Mine does it as well.
That's not true. Boost is typically calculated by the computer taking differences in the barometric sensor, MAP sensor and EBP sensor. If you show negative boost it just means you have a guage reading off a bit. Baro should read 14.7 psi and at idle and the map sensor (and if it has an EBP sensor) should read close to the same. Differences in altitude do affect the readings so it could have to do with your height above sea level as well. Either way, something is a bit off.
StanleyZ
6.7L Power Stroke Diesel
Jul 14, 2019 03:11 PM
remhaust
Sep 3, 2012 12:00 PM
prarrieboyZ
6.4L Power Stroke Diesel
Jul 20, 2011 05:00 PM
Shade
Jul 29, 2008 11:38 AM
haulingboat
Jan 7, 2008 04:59 PM
