Headlight issue
Old Mar 12, 2017 | 04:31 PM
gvagolf's Avatar
gvagolf
Thank you. I was going to use WD-40 but battery terminal cleaner is better.
Thanks again.
Old Mar 13, 2017 | 12:56 AM
Apocalypse's Avatar
Apocalypse
Maybe bust out the soldering iron or at the very least the crimpers and take those wire nuts off the headlights while you're at it too
Old Mar 13, 2017 | 08:40 AM
Futurerider103's Avatar
Futurerider103
th is couldn't hurt either
Old Mar 13, 2017 | 09:41 AM
projectSHO89's Avatar
projectSHO89
If he doesn't, he'll be trying to figure out why the installation failed after only a year or two. Corrosion won't take long, and will be even quicker if he's in the Salt Belt.
Old Mar 13, 2017 | 09:44 AM
Futurerider103
As a mechanic when I am doing any wiring that is susceptible to moisture I use connectors that have heat shrink and solder built into them. They are a little more about $.35 a butt connector but definitely worth it.
Old Mar 13, 2017 | 12:44 PM
agsmv1's Avatar
agsmv1
Those are just for the LED's if I remember correctly..they will go out before the corrosion gets to them, at least mine did.
Cody Wooters
1978 - 1996 Big Bronco
Jan 31, 2016 06:46 AM
mike85120
Oct 11, 2014 11:33 AM
is300wrx
2004 - 2008 F150
19
Jul 24, 2006 12:48 AM
ixtlan
May 13, 2005 08:08 PM
