First start help!?
Old Mar 12, 2017 | 12:47 PM
  #31
dthut's Avatar
dthut
Originally Posted by cmanka28
no you would have to unbolt the NSS it should be behind the shifter on the trans
okay i will try this and get back to you guys.
jist u bolt it, plug it in and it can just dangle there not actually going anywhere?
and if that works just tie it up?
Old Mar 12, 2017 | 12:48 PM
  #32
cmanka28's Avatar
cmanka28
here's my switch
Old Mar 12, 2017 | 01:14 PM
  #33
dthut's Avatar
dthut
Yes!! that did it. engine is cranking from the key now! wahoo. now i will hook up fuel and see if she will fire.
thanks so much guys, i will let you know how it goes
Old Mar 12, 2017 | 03:05 PM
  #34
dthut's Avatar
dthut
okay damn! not sure what happened here. but i'm not getting anything now. all i'm getting is a single click noise from the distributor or coil.
i did all the same tests again
still have power at the ignition switch
nss switch is in park
power to the S terminal when key is turned on
swapped out battery to confirm battery is good.
what at the heck happened? is there a fuse or something i should be checking?
Old Mar 12, 2017 | 03:12 PM
  #35
cmanka28's Avatar
cmanka28
try jumping the solenoid again & see if it still cranks
Old Mar 12, 2017 | 03:19 PM
  #36
dthut's Avatar
dthut
not cranking when i try to jump solenoid
Old Mar 12, 2017 | 03:29 PM
  #37
cmanka28's Avatar
cmanka28
very possible your solenoid just crapped out
Old Mar 12, 2017 | 03:52 PM
  #38
dthut's Avatar
dthut
just swapped out a solenoid from my other truck that i know works. same results.. what else would it be
Old Mar 12, 2017 | 04:04 PM
  #39
cmanka28's Avatar
cmanka28
check to see if your getting power on the starter wire while jumping the solenoid
Old Mar 12, 2017 | 07:20 PM
  #40
dthut's Avatar
dthut
Okay so i figured it out, it was just the NSS. Its i had to wiggle the position it was in, i little turn back from park.
Anyways thanks for all the help guys, couldn't be happier to hear it fire up.
Old Mar 12, 2017 | 07:37 PM
  #41
cmanka28's Avatar
cmanka28
that's awesome glad it fired up
Old Mar 12, 2017 | 07:47 PM
  #42
PapaBearYuma's Avatar
PapaBearYuma
My 77 does the same thing. I drop it into Neutral and it fires right up. Very happy you got it going. Congratulations!!!
azroxx
1997 - 2003 F150
Jun 26, 2019 08:30 AM
sere0501
Sep 19, 2018 01:03 PM
Gjuetar
Dec 14, 2017 03:39 PM
Norma stitz
Sep 30, 2016 05:18 PM
Storm
Sep 27, 2009 08:22 AM
