04 won't throttle up?
Old Mar 8, 2017 | 04:02 PM
docsuby's Avatar
docsuby
Hey guys, Ive got an 04 f150 with the 5.4 in it. It's got a problem that's got me scraching my head. When you drive the truck it will drive fine, but revs like there isn't anything there when it tries to go into overdrive. But if you turn off overdrive, it won't rev much more than 2500 rpm.. Obviously its a sensor issue, but which one? Any insight?
Old Mar 9, 2017 | 07:57 PM
alloro's Avatar
alloro
You could start with the DTR sensor down on the side of the tranny. But to me it sounds more of a mechanical issue than an electrical one.
Old Mar 10, 2017 | 10:40 AM
docsuby's Avatar
docsuby
But, why wont it throttle up when the OD is locked out? that's whats frustrating me
Old Mar 10, 2017 | 11:06 AM
Quinner30's Avatar
Quinner30
So, when it shifts to OD, it is like in neutral, and with OD off its like limp mode?
Old Mar 10, 2017 | 11:13 AM
docsuby's Avatar
docsuby
yep, it runs fine while in normal driving, except the OD miss. But when you lock out the OD it won't run over 2000-2500 rpm
Old Mar 10, 2017 | 11:15 AM
docsuby's Avatar
docsuby
Ive replaced bothe cam phase sensors, and several coil packs to correct missfires.
Old Mar 10, 2017 | 05:48 PM
Quinner30's Avatar
Quinner30
Probably a stupid question, but you have verified plenty of Trans fluid, right?
Old Mar 10, 2017 | 09:58 PM
docsuby's Avatar
docsuby
yeah plenty of fluid.
Old Mar 11, 2017 | 09:43 PM
Bluegrass 7's Avatar
Bluegrass 7
It's time to put a Scanner on and see if any trans codes are present.
You need a place to start instead of guessing.
if the OD light is out and you can't see there is a fault lighting the light.
Good luck
dvblair
2004 - 2008 F150
Jun 1, 2013 09:35 PM
tfink3
2004 - 2008 F150
Jan 6, 2010 03:34 PM
61 uni
Mar 10, 2009 08:39 PM
CM1
Sep 26, 2007 03:37 PM
MemOrex
Apr 6, 2005 03:29 PM
