93 F150 Transmission problem
Old Sep 24, 2007 | 12:08 PM
CM1's Avatar
CM1
all of a sudden while driving my transmission jumped out of Overdrive, it still works in drive and will work (when starting from a dead stop) in OD for a little while and then it acts just like it has been shifted to neutral.
any help would be appreciated
Old Sep 24, 2007 | 12:18 PM
kcb37's Avatar
kcb37
You may have an internal problem, but if you can find out what controls the overdrive you may be able to find a bad sensor or something like that. I wouldn't think that it would be a vss or anything like that. Does it drive fine with the overdrive on until it shifts into od? If so you may have a bad od clutch/band. Not sure what holds od.
Old Sep 24, 2007 | 12:50 PM
CM1's Avatar
CM1
once it starts out in OD it will go for a little while and then quits, if I put it in Drive it will go on and change gears and do everything right, it is just that when I start it out in OD is when I have the problem.
Old Sep 24, 2007 | 02:05 PM
kcb37's Avatar
kcb37
Sounds to me like it may be internal. Could be a check ball, or servo stuck in the vavle body. Something like that. Have you keep up with changing the filter and fluid?
You could try that too. Put some lucas in with it.
Old Sep 24, 2007 | 02:10 PM
CM1's Avatar
CM1
It has been about 40,000 miles since I had the transmission serviced but maybe I should have it done again, what is lucas?
Old Sep 24, 2007 | 02:26 PM
kcb37's Avatar
kcb37
Lucas is an oil treament. If you did the filter and fluid 40,000 miles ago that shouldn't be your problem. How many miles are on your truck?
Old Sep 24, 2007 | 03:54 PM
17fordguy's Avatar
17fordguy
lucas realy aint as good as advertised after it warms up it becomes thinner than the oil and doesnt stick to the gears like all those little modes show at the auto parts store.
Old Sep 24, 2007 | 07:37 PM
CM1's Avatar
CM1
I have about 155000 miles on the truck
Old Sep 24, 2007 | 07:40 PM
CM1's Avatar
CM1
Thanks for letting me know what lucas oil is, I think I will service the transmission again and see if that helps, I tried the truck again today after it cooled down and it seems to work fine for a awhile then starts acting up again. maybe the fluids and filter need to be changed
Old Sep 24, 2007 | 08:02 PM
vinlin95's Avatar
vinlin95
here's something I tried in my 90 w e4od. they call it lube guard. I've been using it in ford trans with o/d surge & it works really well when you service your trans.
Old Sep 24, 2007 | 08:14 PM
CM1's Avatar
CM1
thanks for the tip, I will look for Lube Guard when I change the fluids
I guess any autozone will know what I am looking for.
Old Sep 26, 2007 | 03:37 PM
CM1's Avatar
CM1
I changed out the fluid and filter and now the transmission will shift in overdrive untril it gets to the high gear, then it loses it. My truck has the Automatic Overdrive Transmission. it will drive out OK as long as I keep it in drive, but will not work in OD.
