Engine Boost question
Old Mar 4, 2017 | 05:12 PM
Paule253's Avatar
Paule253
While driving my 2016 F250 which I recently purchased, which has a little over 1000 miles. While driving on the interstate about 65-70 MPH I noticed my gas mileage was reduced to about 11 MPG, normally it is about 16+MPG. I noticed that the Turbo, Engine Boost Gauge was reading about 100 PSI, usually stay about at the zero mark. This situation lasted about 15 minutes, then it returned to normal, both the boost went down and the MPG went back to 16MPG. I did not change my speed. Wondering if this had anything to due with the vehicle's emission control system or the particulate filter regeneration cycle.
Old Mar 4, 2017 | 05:22 PM
dirthawg's Avatar
dirthawg
What you described is exactly what occurs during a regen cycle. You most likely missed the notification on the message center that said "Cleaning Exhaust Filter"
Old Mar 4, 2017 | 07:14 PM
senix's Avatar
senix
the boost guage is X10...so you were only pushing 10psi.
A regen cycle I would agree with.
Old Mar 5, 2017 | 10:55 AM
TeamMudd's Avatar
TeamMudd
Yep that's a regen cycle. I would try and watch for the notification message when I first bought mine. Now I catch a glimpse of the fuel mileage gauge and see the boost above normal and it's in regen. When I go in for my oil change I'm going to ask them if they'll activate the blank screen on the display to show soot percentage. If they want to charge an arm and a leg i'll look into an aftermarket display.
Old Mar 5, 2017 | 11:21 AM
Dakster's Avatar
Dakster
Sounds exactly like a regen.. Did it have a funky smell when you parked? Mine smells like something is burning after a regen. Or at least has a hot smell if I drove a bunch after the regen ended.
Old Mar 8, 2017 | 05:20 AM
94ruck's Avatar
94ruck
smells like burning crayons....yes, i missed the notification the first few times and it was a head scratcher at first...
don't have that particular situation anymore.
Old Mar 8, 2017 | 12:29 PM
69cj's Avatar
69cj
I can see when mine's in regen by the egt temps. Normally 400 to 500 degrees will go as high as 1200 during regens.
Paule253
Mar 4, 2017 09:10 PM
KC8QVO
6.4L Power Stroke Diesel
Sep 18, 2010 06:40 AM
hndacr
Jan 18, 2010 07:42 PM
cdiddy
29
Feb 7, 2008 12:26 PM
kmejr09
Sep 21, 2007 11:53 AM
