Boost, Turbos, Mileage
Second topic - I notice a sucking noise from the truck, like a vaccum cleaner, every time the boost is between 100 and 180lbs or so. Closer to 200lbs the typical turbo whine kicks in over the vaccum. What is the vaccum sound and why does it take the boost pressure to go up so much before the "normal" turbo whine kicks in? Like if I am in 5th gear and push the petal down to accelerate, but not to the point where it down shifts, I hear the turbo spool up with the whine up around 200lbs boost and the truck pushes you back in the seat. I haven't pushed it past 75mph so I don't know how high the boost pressure will go, not really a concern, but I would like to understand it a little better.
Third topic - My last tank I was well over 17mpg. I don't have my receipt in front of me where I wrote it all down, but the calculated was something like 17.5 and the meter was 16.8. Is that "pretty close" or are some of yours even closer? I know some people's are way off (calculated vs. meter). I re-set my mpg with each fill-up, as well as one of my trip meters. I do only go to 1/4 to get around the $75 pre-pay limit. Otherwise its a pain in the butt.
This next tank should be even better than my last one - I spent a lot of time on the highway for the first 1/4 tank. The meter is showing 17.4 as of when I pulled in the driveway.
I think with the DPF is does not sound as normal exhaust would sound.
You have a sequencial turbo, smaller to get bigger going.
Scott - Does the smaller turbo make the sucking noise rather than the whine then?
Another question - why is there the lag? Does the engine just need to build some RPM's before the turbos can catch up and thus the time delay in petal-down vs. take-off-and-go? Thats an extra "sense"/"skill" I need to add to my driving enncyclopedia - factoring in the pickup time in manuvering decisions.
I'm in no way an expert but I think it's the other way around.
The engine is ready but the turbo takes a second or two to spool up and aid the engine in accleration. Just give yourself extra time when pulling out although I do realize you can't always apply that logic. There has to be enough exaust pressure to spin the small turbine at a useful speed.
That is why you will see some off the line with black smoke.
Ours will not have that because of the emissions will not allow an overfueling to occur.
Each mark on the boost guage is 10 psi for a max of 40.
Max this motor can take is 41 psi. More than that and it would blow its top.
