Sponsored by: Real Truck
Turbo Question
Old Mar 4, 2017 | 05:10 PM
Paule253's Avatar
Paule253
Turbo Question
While driving my 2016 F250 which I recently purchased, which has a little over 1000 miles. While driving on the interstate about 65-70 MPH I noticed my gas mileage was reduced to about 11 MPG, normally it is about 16+MPG. I noticed that the Turbo, Engine Boost Gauge was reading about 100 PSI, usually stay about at the zero mark. This situation lasted about 15 minutes, then it returned to normal, both the boost went down and the MPG went back to 16MPG. I did not change my speed. Wondering if this had anything to due with the vehicle's emission control system or the particulate filter regeneration cycle.
Old Mar 4, 2017 | 05:46 PM
Desert Don's Avatar
Desert Don
100 PSI boost????? WOW!!
Old Mar 4, 2017 | 08:30 PM
kansas gary's Avatar
kansas gary
That is some serious boost if its even close to 100 lbs of boost.... My exhaust temp would be close too 1900 degrees with that much boost.............
Old Mar 4, 2017 | 09:09 PM
Jetvette1's Avatar
Jetvette1
Exhaust revenue ?
sounds like your exhaust went through a regen. It happens occasionally and you only get a very brief message on your instrument message center before it starts automatically . It's a self cleaning function.
It lasts about 20 miles or so.
Its normal.
You may get a hot exhaust smell as well.i believe it works by extra fuel being added to your exhausts system that creates a scorching/burn it clean situation.
There shoykd be more info in your diesel supplemental booklet.
Old Mar 4, 2017 | 09:10 PM
Jetvette1's Avatar
Jetvette1
Not sure about the turbo indication......
jump05powerstroke
6.7L Power Stroke Diesel
Apr 22, 2017 11:56 PM
Paule253
Mar 8, 2017 12:29 PM
KC8QVO
6.4L Power Stroke Diesel
Sep 18, 2010 06:40 AM
trtex
Jun 13, 2009 06:38 AM
kmejr09
Sep 21, 2007 11:53 AM
