dirty transfer case fluid
Old Feb 25, 2017 | 07:36 PM
farmerchad's Avatar
farmerchad
Hello, couple of questions on my 04 XL transfer case, 107,000 miles new to me, as I took out plug to check level air was sucking in around the threads like the case was sealed air tight, is there a vent that is plugged or is it sealed tight?
Next thing was that the fluid was muddy brown, smelled like atf but looked crappy brown. Didn't look foamy like water, I guess it's troubling if it's heat related, I'll put clean fluid in and see what happens.
Old Feb 26, 2017 | 08:08 PM
1saxman's Avatar
1saxman
Most of them take ATF. If yours does, try Valvoline Max Life Dex/Merc. Best ATF out there. When I had a Jeep Cherokee, I changed the transfer case ATF after a couple of years and it was pretty dark. Subsequent changes were much better. And it doesn't matter if you ever use 4WD or not - it still gets used up.
Old Feb 28, 2017 | 06:00 PM
wheelerfreak's Avatar
wheelerfreak
It has a vent so you may want to check that it's not plugged. I change mine every 30k and even then it has looked pretty bad when I changed it. I just used Mercon V.
texrdnec
May 10, 2017 06:40 PM
fishbones182
Dec 30, 2015 07:24 AM
straightsixer
Apr 21, 2008 03:37 PM
crazylewi
Oct 30, 2006 07:12 PM
stepside64
Mar 26, 2004 11:00 AM
