My 2004 FX4 5.4 has the infamous tick noise :'(
Hello all.
My old boy, Blue (my truck: 2004 FX4 5.4 w/157k miles) has always had a tick noise even when we rolled it off the showroom floor brand new in 2004. But now it is older and the "tick" noise has become more pronounced. Last summer I had Cam Phasers/solenoids replaced....still ticks and btw...(Bob Schwartz Ford in Peru, IN have terrible service and over charged me $800). This past spring I took old Blue to Brad Howell Ford and they seem like they have a good handle on this issue. They ran all sorts of tests: Compression, Oil, etc and they all came back perfect. No engine probs but they all can hear the notorious tick. They have suggested to just let it be because it's not causing any problems and especially since it has ticked loudly for tens of thousands of miles. They think they have it narrowed down to 1-2 lifters on one side but they feel that I should leave it alone since it's performing perfect. They also put Lucas Oil stuff in every oil change from here on out...just in case. I'm picky and I don't like the way my truck sounds. It sounds like a ticking bomb when I'm waiting in the fast food drive through!
What would all you boys do if this was your truck?
If it sounds like the sound of lifters, and you can isolate it to certain cylinders, do not just let it go. I had the exact same symptoms on my '07. Ticking, like a collapsed lifter, with a stethoscope isolated to 2 cylinders. And like your truck, performance was about the same, and no check engine lights or any other signs, except for the tick. Turns out the rollers on 2 cam followers failed, so instead of rolling along on the cam lobe they were scoring the lobes. Long story short, I had to replace the cam, and the bad followers. Everything else was fine, luckily no other damage. I would look into fixing the problem asap. Metal on metal, grinding away in the engine is not good.
FYI, the repair is kind of easy, and with the tools and parts, cost was around $500. Only way to check for sure is to pull the valve cover.
My answer would depend on how much longer you plan to keep the truck. I do agree that metal on metal is a bad thing and if your problem is similar to Gary's then I would try to find where the noise is coming from and repair it. If it has ticked since day one I probably would have never bought the truck to begin with. But then again maybe it was a very quiet tick. If you plan to keep it for awhile longer I would repair it if possible. I'm sure you know that this can get expensive depending on what it is. Best of luck.
Hello all.
Even the mechanically challenged can use an engine stethoscope to identify the area a noise is originating. If the sound is coming from the valve cover, then it probably is a sticking valve or bad follower, or similar. If it's coming from the front of the engine, then you have other problems that bear investigation.
Whatever is causing the sound is not going to be fixed by adding magic in a bottle. They are attempting to treat a symptom, not cure a problem.
EDIT: I can't believe I got suckered into responding to a nine month old post!
Hello all.
But hours of reading these reviews reveal two things:
1) put a stethoscope to it, check 1 and 2.
2) check the manifold, sounds like a gasket could be your problem when the cam phasers, Etc. have been taken care of.
@MJservices....
I found a mechanic who works out of his garage after his day job at a Ford Dealer. He found the problem. All but 4 lifters were broken or stuck. I had all lifters replaced. Running perfect and not using any oil now.
I just put in a remanufactured transmission in this summer as I lost my reverse and overdrive gear.
Been an expensive truck but oh well. it beats having a truck payment!
ticking noise
@MJservices....
My 04 FX4 started making the noise around 40k and has now turned into a marching band. It also makes a very clattery sound at start up and it lasts only a few seconds until the idle settles down. It's an exciting event every time. I have 161k on it now. Any thoughts? I'm getting all the info I can in order to take it to a shop for repairs. I love this truck BTW!
Did the noise go away?
thompsdw
Modular V8 (4.6L, 5.4L)
22
10-21-2014 01:26 AM
